I can’t find the specs of the S170 temp/humidity sensor anywhere. For example, the temperature and humidity ranges, accuracy tolerances, etc…
thanks in advance, Buddy
Hello, this should help:
Hi there,
I´m designing a device using the SI70 and autodesk fusion 360, but the step file is not present. Can you share the file so I can design my device with it?.
Thanks.
@ r.ricardog - Unfortunately we do not provide step files anymore.
Hi John,
Is there any other way to solve this?. Are there any other sites where I can find this?
Thanks.
@ r.ricardog - What specific information are you looking for?
John,
I´m trying to reproduce the board as part of the Autodesk 360 Fusion tool to design the device that will containg this sensor as one of it´s parts. So, if I don´t have the exact shape in 360 it will cost me more money and time to acomplish this task.
Thanks.
@ r.ricardog - are you talking about the TempHumid sensor module ? Could you not open the Eagle files and play with the Eagle magic to export a 3d representation?
