As the music module is no longer available, what alternative is there for adding sound output to a NETMF design?
I need to playback voice prompts and beeps and whistles etc from a G120 based design.
Thanks Andre, I need something I can lay out on a PCB along with the G120 module so I will check out further your suggestions.
Hopefully drivers are easy as the time on this project is short.
