Hi everybody,
i want to create a equalizer with my 4-digit-shield http://www.suplanus.de/4-digit-shield-class/
Want to show the loudness an nodes (spectrum) of the music.
Which module i need?
In the forum i only found this http://www.tinyclr.com/forum/topic?id=1520
Is this mic ok?! http://www.sparkfun.com/products/8669
Greets
Johann
I think what you want is a spectrum analyzer (using FFT f.e.) not an equalizer.
You could use an audio encoding chip, but your result will not be real-time. AFAIK there is no module with a AD convertor that takes a microphone input…
try this I used it in a project
http://www.sparkfun.com/products/10306 with the FEZ Panda not sure how it would work with Gadgeteer you can also buy the chip used on it ( MSGEQ7) and make you own circuit. I am working on that now but its is weeks away
Here’s a project using FFT: http://www.tinyclr.com/codeshare/entry/421
Pop in the TinyCLR community IRC channel and ask/chat
about whatever you want.
