Something broke (Spider or Display T35)
I’ve been working on a few coding problems and all of a sudden, my Display_T35 module has shifted up about a half line. WHen I reset, the screen turns white, and them DIsplays
“EMX
Version 4.2.7.0
Debug: COM1
LCD: 320x240”
But! half of the EMX is off the screen at the top. This just changed, but I am perfuzzled. I tried reseting, powering off (with a minute or so wait) all to no avail.
What could have happened?
First step, make sure you have T35 and not TE35 referenced. Using the wrong one will cause problems.
It sounds as if the LCD config was altered somehow. A quick way to reset it would be to start a blank Gadgeteer project and only attach the screen in the designer. run the program and that should reset the screen to original specs.
And Skewworks is also correct. The TE35 and T35, while virtually identical have a few differences in config settings.
SOLVED!!! Thanks, Skewworks - that was it. In my dull stupor, I picked the wrong module.
