Hello,
I have a curious issue: a button is connect on socket 7, and a breadboard on socket 6. I test interrupt with the button on breadboard (wired to pin3). Interrupt works perfectly.
The button on socket 7 raise the interrupt (but just on falling edge): why ?
I must forget something, but I can find it !
public partial class Program
private bool _bMainboardLed;
private bool _bBreadBoardLed;
private DigitalOutput _doBreadboardLed;
private InterruptInput _iiBreadbordButton;
private InterruptPort _breadboardButtonInterruptPort;
timer.Tick +=<tab><tab>
timer.Start();
_bMainboardLed = false;
Mainboard.SetDebugLED(_bMainboardLed);
// Configure button behavior
button.Mode=Button.LedMode.OnWhilePressed;
button.ButtonPressed += button_ButtonPressed;
// Configure Breadboard Input/Output
_bBreadBoardLed = false;
// Led connected on port 4 as digital output
_doBreadboardLed = breadBoardX1.CreateDigitalOutput(GT.Socket.Pin.Four, _bBreadBoardLed);
// Button connected on port 3 as digital input/interruption
_iiBreadbordButton = breadBoardX1.CreateInterruptInput(GT.Socket.Pin.Three, GlitchFilterMode.On, ResistorMode.PullUp,
InterruptMode.RisingAndFallingEdge);
_iiBreadbordButton.Interrupt += _iiBreadbordButton_Interrupt;
FlashMainboardLed();
void _iiBreadbordButton_Interrupt(InterruptInput sender, bool value)
Debug.Print(sender.ToString()+","+value);
void button_ButtonPressed(Button sender, Button.ButtonState state)
_doBreadboardLed.Write(!_doBreadboardLed.Read());
private void FlashMainboardLed()
var tMainboard = new Thread(() =>
for (int i = 0; i < 5; i++)
_bMainboardLed = !_bMainboardLed;
Thread.Sleep(100);
tMainboard.Start();
