Well, i just got my fez domino, and I’m trying to upgrade my firmware. I am able to connect to the fez, and the boot loader version is 1.07.
My firmware version was not the same as the one in the SDK (older), so I need to flash the latest…
So I’m following the tutorial, and when I try to load the firmware, I cannot locate the file “FEZ Domino & Mini.GHI”, all I can find is “USBizi_CLR.GHI” in the “GHI NETMF v4.1 SDK” directory.
I am also not able to Ping the device, but I can connect to, and was able to run an app in the device…
Also, in Visual C#, when I “Add References”, there is nothing in the “.NET” directory…
Also… for some reason, When adding references do it from the solutions window on the right… Right click on add reference… The solution window must be in focus before you can see the .net references
