i have a Cerbuino Bee and a Seeed Studio Groove Motor Driver and today i tested it.
I downloaded the code snipped from “Bec a Fuel” that can handle this motor driver but it requires a board with hardware I2C and now i know that the cerbuino only supports software I2C.
So i tested it for myself:
Cpu.Pin I2C_SDA = FEZCerbuinoBee.Pins.D3;
Cpu.Pin I2C_SCL = FEZCerbuinoBee.Pins.D4;
I2CBus = new SoftwareI2CBus(I2C_SCL, I2C_SDA);
I2C = I2CBus.CreateI2CDevice(Address);
var bytesSent = I2C.Write(new byte[] { MotorSpeedSet, 0, 100 });
But that only works [em]sometimes[/em].
I dont get it when it works and when not.
In the code snipped from “Bec a Fuel” he uses transaction based I2C. Is it a difference to the array that i send? Could this be the problem?
Or are there other issues with software I2C?
Thank you!
Daniel
Sources:
SeeedStudio I²C motor driver
https://www.ghielectronics.com/community/codeshare/entry/435
Seeed Motor Driver:
http://www.seeedstudio.com/wiki/Grove_-_I2C_Motor_Driver_V1.3
http://www.robotshop.com/media/files/pdf/datasheet-rob72212p.pdf
