I’ve been struggling with getting the socket connection between a Spider and WinPhone7 client to work correctly but it just isn’t happening. I started out with Marco’s SocketServer class and the MSDN example socket client for using SocketAsyncEventArgs for WP7 (WP7 can’t use the regular non-async socket methods) and, since neither of them supports sending data from server to client I built out logic to do that. Total message length is determined by prepending the four-byte integer length to the message, once the connection is established the client receives over and over and whenever a full message has been received an event on the client class is raised. This works fine for occasionally sending small amounts of data but some really strange stuff is happening when I send a 57000 byte test pattern. If I do it as a single socket.Send(data) method call the client bombs out because it tries to read something that isn’t the first received packet as the first received packet (leading to thinking it’s got a huge message and exceeding the 80k message-processing buffer) and if I break it into 1024 byte chunks and send each individually only 42-43 of the 56 total chunks get processed.
Either way, the issue is that data is clearly being lost between the server send method and when the client is finished processing the message. I’m relatively sure the problem lies in the client’s receive handler, which is wired up to the SocketAsyncEventArgs Completed event, though being socket communication betweeen two very niche technologies it could be anything. Here’s the relevant code for both the main receive loop and the completed event handler method:
void socketEventArg_Completed(object sender, SocketAsyncEventArgs e)
try
if (e.SocketError == SocketError.Success)
if (!isReceiving)
// If this is the first part of the message, pull off the first four bytes as that's our length
byte[] len = new byte[4];
len[0] = e.Buffer[0];
len[1] = e.Buffer[1];
len[2] = e.Buffer[2];
len[3] = e.Buffer[3];
msgLen = BitConverter.ToInt32(len, 0);// maybe refactor this to get rid of len and just hit buffer?
isReceiving = true;
rcvIndex = 0;
chunks = 0;
buffer = new byte[MAX_MSG_SIZE];
partList.Clear();
// Copy this into the buffer at the appropriate spot
chunks++;
// Find any occurrences of 101 and read the next thing in sequence
for (int v = 0; v < e.Buffer.Length - 1; v++)
if (e.Buffer[v] == 101)
partList.Add(e.Buffer[v + 1]);
// NOTE: This only works properly if the total message length is always less than the buffer
// which for this application is true--the max msg size is 80k but images are only around 60
e.Buffer.CopyTo(buffer, rcvIndex);
rcvIndex += e.BytesTransferred;
// Is this the end of the message?
if (rcvIndex >= msgLen)
count++;
// Done receiving, so do the callback
isReceiving = false;
OnMessageReceived(new SocketReceivedEventArgs(buffer, chunks));
// Call the loop again
ReceiveLoop();
OnMessageReceived(new SocketReceivedEventArgs(Encoding.UTF8.GetBytes(e.SocketError.ToString()), 0));
catch
partList.Add(-1);
throw;
private void ReceiveLoop()
// We are receiving over an established socket connection
if (_socket != null)
// Make an asynchronous Receive request over the socket
_socket.ReceiveAsync(socketEventArg);
OnMessageReceived(new SocketReceivedEventArgs(Encoding.UTF8.GetBytes("Socket is not initialized"), 0));
Any ideas what I’m doing wrong? My best guess is that the buffer is getting overwritten while socketEventArg_Completed is still processing, though that doesn’t make a lot of sense to me given that the next receive isn’t fired until the processing is done.
