Ok, I understand that VS will create the code behind, but I still do not understand what I need to put into my code so that VS will know where to put the socket number and instantiate the module driver.
With regard to the initialize method for my module, my background is with PIC micro’s and I am used to create a initialization section where I run all my initialization routines to set all the different component and devises up. This normally only runs during start-up of PIC. So with a HD44780 compatible 2 x16 LCD as a first step my first step have to initialize the LCD itself. So what I am trying to achieve is to capture the socket number, and then to send the initialization sequence to the LCD. My module code looks like this:
using Gadgeteer;
using Gadgeteer.Modules;
using Gadgeteer.Interfaces;
namespace Gadgeteer.Modules.Zoftworx
/// <summary>
/// A LCD2X16 module for Microsoft .NET Gadgeteer
/// </summary>
public class LCD2X16 : Gadgeteer.Modules.Module
Socket _socket;
DigitalOutput _LCD_RS;
DigitalOutput _LCD_E;
DigitalOutput _BackLight;
DigitalOutput _LCD_D4;
DigitalOutput _LCD_D5;
DigitalOutput _LCD_D6;
DigitalOutput _LCD_D7;
const byte DISPLAY_ON = 0xC; // Turn visible LCD on
const byte DISPLAY_CLEAR = 0x01; // Clear display
const byte DISPLAY_BLANK = 0x08; // Blank the display (without clearing)
const byte DISPLAY_RESTORE = 0x0C; // Restore the display (with cursor hidden)
const byte CURSOR_HOME = 0x02; // Move cursor home and clear screen memory
const byte SET_CURSOR = 0x80; // SET_CURSOR + X: Sets cursor position to X
const byte SCROLL_RIGHT = 0x1E; // Scroll display one character right (all lines)
const byte SCROLL_LEFT = 0x18; // Scroll display one character left (all lines)
const byte CURSOR_LEFT = 0x10; // Move cursor one character left
const byte CURSOR_RIGHT = 0x14; // Move cursor one character right
const byte CURSOR_UNDERLINE = 0x0E; // Turn on visible underline cursor
const byte CURSOR_BLINKING = 0x0F; // Turn on visible blinking-block cursor
const byte CURSOR_INVISIBLE = 0x0C; // Make cursor invisible
/// <summary>
/// Initialize the LCD Display for 4 bit data communication.
/// </summary>
/// /// <param name="socketNumber">The socket the module is plugged in to.</param>
public void Initialize(int socketNumber)
// set the socket up
_socket = Socket.GetSocket(socketNumber, true, this, null);
//_socket = Socket.GetSocket(, true, this, null);
// define all the pins on the selected socket
_LCD_RS = new DigitalOutput(_socket, Socket.Pin.Four, false, this);
_LCD_E = new DigitalOutput(_socket, Socket.Pin.Three, false, this);
_BackLight = new DigitalOutput(_socket, Socket.Pin.Five, false, this);
_LCD_D4 = new DigitalOutput(_socket, Socket.Pin.Six, false, this);
_LCD_D5 = new DigitalOutput(_socket, Socket.Pin.Seven, false, this);
_LCD_D6 = new DigitalOutput(_socket, Socket.Pin.Eight, false, this);
_LCD_D7 = new DigitalOutput(_socket, Socket.Pin.Nine, false, this);
// start the LCD initialization procedure
_LCD_RS.Write(false);
Thread.Sleep(50);
_LCD_D7.Write(false);
_LCD_D6.Write(false);
_LCD_D5.Write(true);
_LCD_D4.Write(true);
_LCD_E.Write(true);
_LCD_E.Write(false);
Thread.Sleep(50);
_LCD_E.Write(true);
Thread.Sleep(50);
_LCD_E.Write(true);
Thread.Sleep(50);
_LCD_D4.Write(false);
_LCD_E.Write(true);
BacklightOff();
SendCommand(DISPLAY_ON);
SendCommand(DISPLAY_CLEAR);
/// <summary>
/// Sends a LCD command.
/// </summary>
/// <param name="c">Sends a commands to LCD for example '0xC' that is the command to turn the DISPLAY ON</param>
void SendCommand(byte c)
_LCD_RS.Write(false); //set LCD to data mode on
_LCD_D7.Write((c & 0x80) != 0);
_LCD_D6.Write((c & 0x40) != 0);
_LCD_D5.Write((c & 0x20) != 0);
_LCD_D4.Write((c & 0x10) != 0);
_LCD_E.Write(true); //Toggle the Enable Pin on
_LCD_E.Write(false); //Toggle the Enable Pin off
_LCD_D7.Write((c & 0x08) != 0);
_LCD_D6.Write((c & 0x04) != 0);
_LCD_D5.Write((c & 0x02) != 0);
_LCD_D4.Write((c & 0x01) != 0);
Thread.Sleep(1);
_LCD_RS.Write(true); //set LCD to data mode off
/// <summary>
/// Sends an ASCII character to the LCD
/// </summary>
/// <param name="c">ASCII character</param>
void PutChar(byte c)
Thread.Sleep(1);
/// <summary>
/// Sends a string of ASCII characters to the LCD
/// </summary>
/// <param name="str">Text string (ASCII characters)</param>
public void PutString(string str)
for (int i = 0; i < str.Length; i++)
PutChar((byte)str[i]);
/// <summary>
/// Clear the contents of the screen
/// </summary>
public void DisplayClear()
/// <summary>
/// Blank the display (without clearing)
/// </summary>
public void DisplayBlank()
SendCommand(DISPLAY_BLANK);
/// <summary>
/// Restore the display (with cursor hidden)
/// </summary>
public void DisplayRestore()
SendCommand(DISPLAY_RESTORE);
/// <summary>
/// Move cursor home and clear screen memory
/// </summary>
public void CursorHome()
SendCommand(CURSOR_HOME);
/// <summary>
/// Sets cursor position to postion X on the LCD. You have to specify the Line number and Column number.
/// </summary>
/// <param name="row">Indicates the row number. "0" indicates Line 1, "1" indicates Line 2, etc.</param>
/// <param name="col">Indicates the position from the leftmost character of the LCD. For example, if you put "0" then it points to the left-most position on the line</param>
public void CursorSet(byte row, byte col)
SendCommand((byte)(SET_CURSOR | row << 6 | col));
/// <summary>
/// Takes the cursor to first character position on Line 1 of the LCD display
/// </summary>
public void GotoLine1()
CursorSet(0, 0);
/// <summary>
/// Takes the cursor to the first characted position on Line 2 of the LCD display
/// </summary>
public void GotoLine2()
CursorSet(1, 0);
/// <summary>
/// Turn the LCD backlight on
/// </summary>
public void BacklightOn()
_BackLight.Write(false);
/// <summary>
/// Turn the LCD backlight off
/// </summary>
public void BacklightOff()
_BackLight.Write(true);
/// <summary>
/// Scroll display one character right (all lines)
/// </summary>
public void DisplayScrollRight()
SendCommand(SCROLL_RIGHT);
/// <summary>
/// Scroll display one character left (all lines)
/// </summary>
public void DisplayScrollLeft()
SendCommand(SCROLL_LEFT);
/// <summary>
/// Move cursor one character left
/// </summary>
public void CursorLeft()
SendCommand(CURSOR_LEFT);
/// <summary>
/// Move cursor one character right
/// </summary>
public void CursorRight()
SendCommand(CURSOR_RIGHT);
/// <summary>
/// Turn on visible underline cursor
/// </summary>
public void CursorUnderline()
SendCommand(CURSOR_UNDERLINE);
/// <summary>
/// Turn on visible blinking-block cursor
/// </summary>
public void CursorBlinking()
SendCommand(CURSOR_BLINKING);
/// <summary>
/// Make cursor invisible
/// </summary>
public void CursorInvisible()
SendCommand(CURSOR_INVISIBLE);
So, at the moment, if I connect the LCD to FEZ Spider, then I have to call the
and input the actual socketNumber that I used to plug my module into.
If this is not the correct way of achieving this, then how and where should I include the LCD initialization code for my own LCD module?
Thanks for your futher information.
