Hi There,
I would like to know if there is some socket available for the EMX module?
I have two reasons for wanting this:
Easy to add and remove the module. I have managed to damage some modules in the past (due to incompetence of my own :-[) but I’m never able to remove the modules from my board to sent them out for repairs. Any hints for de-soldering the module are also welcome!
I would like to develop a board containing more than one module, based on customber options. This means that I would like to have the option to add additional modules when needed. In order to pre-produce the board, it would be very helpfull if I could add the modules later.
At this time, I produced a small print which I can stack on a header. On the small print, the module is soldered. This works fine, but to expose all pins, I need a rather large header. It also leaves me with the “not beeing able to return a defective module” problem, since the module is still soldered.
Any input is appreciated.
