I’m running into an issue when creating a new “listener” for a very basic web server. I have included a screenshot of the bind exception and sample code to recreate the error. The behavior that I find strange and makes me think this might be a bug is that I can create a new listener object the destroy it over and over again (no problem at all). However, once the listener/socket processes some type of traffic I can never bind to it again without getting an InvalidOperationException. A few things I have tried to fix the issue with no success including:
- When, what order and at what point I bind to the listener in the creation process.
- Tried using both ethernet and wifi connection.
- Assigning a specific endpoint instead of IPAddress.Any.
- Timing delays
- Using a Fez Duino board too
To run this example you will need to launch a web browser and send at least one request to the server on port 80. The bind will only fail once traffic has been previously processed. Binding without any traffic being process will work without issue and behaves as expected.
Any thoughts you might have would be apricated!
using System.IO;
using System.Net;
using System.Text;
using System.Net.Sockets;
using System.Diagnostics;
using GHIElectronics.TinyCLR.Devices.Network;
namespace Bytewizer.TinyCLR.WebServer
class Program
static void Main()
// Initialize SC2026D development board ethernet
InitializeEthernet();
var server = new HttpServer();
server.Start();
server.Stop();
server.Start();
private static void InitializeEthernet()
var networkController = NetworkController.FromName(SC20260.NetworkController.EthernetEmac);
var networkInterfaceSetting = new EthernetNetworkInterfaceSettings
MacAddress = new byte[] { 0x00, 0x8D, 0xA4, 0x49, 0xCD, 0xBD },
IsDhcpEnabled = true,
IsDynamicDnsEnabled = true
networkController.SetInterfaceSettings(networkInterfaceSetting);
networkController.NetworkAddressChanged += NetworkAddressChanged;
networkController.SetAsDefaultController();
networkController.Enable();
private static void NetworkAddressChanged(
NetworkController sender,
NetworkAddressChangedEventArgs e)
var ipProperties = sender.GetIPProperties();
var address = ipProperties.Address.GetAddressBytes();
if (address != null && address[0] != 0 && address.Length > 0)
Debug.WriteLine($"Lauch web brower on: http://{ipProperties.Address}");
public class HttpServer
private Thread _thread;
private Socket _listener;
private bool _active = false;
private readonly ManualResetEvent _acceptEvent = new ManualResetEvent(false);
private readonly ManualResetEvent _startedEvent = new ManualResetEvent(false);
public void Start()
// Don't return until thread that calls Accept is ready to listen
_startedEvent.Reset();
// create the socket listener
_listener = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
_listener.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.ReuseAddress, true);
_listener.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.KeepAlive, true);
// bind the listening socket to the port
IPEndPoint endPoint = new IPEndPoint(IPAddress.Any, 80);
_listener.Bind(endPoint);
// start listening
_listener.Listen(5);
_thread = new Thread(() =>
_active = true;
AcceptConnections();
_thread.Priority = ThreadPriority.AboveNormal;
_thread.Start();
// Waits for thread that calls Accept() to start
_startedEvent.WaitOne();
Debug.WriteLine($"Started socket listener");
public void Stop()
_active = false;
// Signal the accept thread to continue
_acceptEvent.Set();
// Wait for thread to exit
_thread.Join();
_thread = null;
_listener.Close();
_listener = null;
Debug.WriteLine("Stopped socket listener");
private void AcceptConnections()
// Set the started event to signaled state
_startedEvent.Set();
while (_active)
// Set the accept event to nonsignaled state
_acceptEvent.Reset();
Debug.WriteLine("Waiting for a connection...");
using (var remoteSocket = _listener.Accept())
// Set the accept event to signaled state
_acceptEvent.Set();
// Send response to client
Response(remoteSocket);
// Close connection
remoteSocket.Close();
// Wait until a connection is made before continuing
_acceptEvent.WaitOne();
Debug.WriteLine("Exited AcceptConnection()");
private void Response(Socket socket)
using (var network = new NetworkStream(socket))
using (var reader = new StreamReader(network))
while (reader.Peek() != -1)
var line = reader.ReadLine();
Debug.WriteLine(line);
string response = "HTTP/1.1 200 OK\r\nContent-Type: text/html; charset=UTF-8\r\nConnection: close\r\n\r\n" +
"<doctype !html><html><head><title>Hello, world!</title>" +
"<style>body { background-color: #111 } h1 { font-size:2cm; text-align: center; color: white;}</style></head>" +
"<body><h1>" + DateTime.Now.Ticks.ToString() + "</h1></body></html>";
var bytes = Encoding.UTF8.GetBytes(response);
network.Write(bytes, 0, bytes.Length);
