Snippet - TCP/IP Thermal and Humidity sensor driver
This class is a simple “driver” class that get an xml stream over http from the HWGROUP™ T/H Sensor model HWg-STE.
This sensor is very interesting due to the fact it is directly pluggable to an ethernet network and can be supplied via POE injection.
The following class decode the xml file that can be read over http, and extract the temperature and humidity provided by the module. It also manage that in some case, just the temperature sensor is provided.
I often use this to pilot such sensor in datacenter racks, and provide such an HMI based on the CHIPWORKX DevKIT MODULE.
