This is still needs some tweaks. The //TODO: and //NOTE: mention any issues.
A implementation of System.Xml.Serialization.XmlSerializer from desktop .NET to work on NETMF. This allows you to share a common data class between any .NET applications (desktop, compact and micro) and have the data in the class be serialized to and from XML it in any of those environments. Almost all primitive value types are supported. The known types that are not in parity with desktop .NET are Enums, byte[], embedded structs and embedded classes.
@ JREndean,
I got some problem in deserialization. I suggest a modification like this:
public object Deserialize(Stream stream)
object instance = this.typeToSerialize.GetConstructor(new Type[0]).Invoke(null);
// Use XmlReaderSettings
XmlReaderSettings xmlrdr_settings = new XmlReaderSettings();
xmlrdr_settings.IgnoreWhitespace = true;
// I suggest this becouse .NET serializer use by default "\n" after tag so better to have "IgnoreWhitespace = true"
using (XmlReader xmlReader = XmlReader.Create(stream, xmlrdr_settings))
