Snippet - NETMF BME280Device Driver
I just posted NETMF BME280Device Driver on Codeshare. Feel free to discuss and make suggestions here.
Something is wrong with your calculation for Pressure. When running your code, it tells me that my Pressure is about 775 mBar.
That would mean that my altitude would be around 7000 - 8000 feet which is not correct.
Typical uncompensated pressure for my altitude (142 meters) is around 1006 to 1014 mBar which correlate quite well to my Analog and Digital Barometers. As well as my local weather station when applying accepted Seal Level Compensation formulas.
@ srogers -
I have posted the in-depth documentation for this driver at:
[url]https://drive.google.com/file/d/0B9hU8MaTMFJgWVc0WUYwSjFLNk0/view?usp=sharing[/url]
@ scardinale -
Here is a test of the sample code I provided for the driver:
AltitudeInFeet = 350.0F
// Webster NY is 425.0 feet (I presume at city hall)
// I found that setting an altitude setting of 350 F for my
// location matches a nearby weather station’s barometric
// pressure and has tracked that station within 0.01 inHg for
// three consecutive days through considerable barometric
// pressure deviations in Webster. I consulted a topographical
// map of my location in Webster. I am within 1/4 mile of a
// 400 ft elevation line on that map. I am in my basement
// which would drop me maybe 10 or 13 feet from grade level
// outside.
// The debug output from the test program is as follows:
TempC=20.9 Pressure (in millibars)=1024.16 Relative Humidity=41.10
TempF=69.6 Pressure (inches Hg)=30.24 Relative Humidity=41.10
// Here is the simultaneous Webster, NY weather report for that time.
// I live in Webster, NY.
Current Report for Sun Nov 15 2015
As of 11:54 PM EST SAT NOV 14 2015
36°F 2°C
// My temperatures readings are indoor
Webster weather conditions : Partly Cloudy
Barometer: 30.23 inHg. steady
// My pressure readings inHg closely match
// Webster weather.
Humidity: 73%
// My humidity reading is indoors.
Can you tell me a little more about your setup to test the driver, in particular, what breakout board you are using, if any, and what NETMF board you have? All my work is done on the Cobra III board.
Are you just checking the sea-level barometric pressure conversion code, or are you checking a complete system with a BME280 device connected?
I am committed to resolving this issue, once I understand it completely.
I am using a Mikrobus.Net Quail board using a MikroE Weather click which is based on the BME280. I have also tested your code with a MBN BME280 module.
The values returned for pressure is always around the 700 bar range. When I test using the Mikrobus.Net Weather Click driver the both report around 1012 mbar.
I will test this on a Cobra II board to see if this makes any difference, but I doubt that it will.
P.S. My Zip Code is near yours 13317.
@ scardinale -
As I cannot duplicate the results you have reported with my driver and my hardware, I wonder if you would offer to do a test for me?
In my driver code, only the following variables can affect the output of pressure when the AltitudeInFeet property is set to 0.00:
[ul]The TemperatureFine value – property int TemperatureFine
The nine pressure trimming values: ushort dig_P1, short dig_P2, dig_P3, dig_P4, dig_P5, dig_P6, dig_P7, dig_P8, dig_P9
The raw pressure value read from the chip – property Int32 RawPressureADC[/ul]
Please do the following:
[ol]Set ReportPressureInMillibars to false
Set AltitudeInFeet to 0.0F
Set a breakpoint at the start of the method GetCompensatedPressureInInchesHg()
Examine ‘this’ variable, a BME280Device object, and report the values of:[ul]TemperatureFine
RawPressureADC
All nine Dig_P* variables[/ul]
Then run any other program that you have that reports different barometric pressures and get the same values (which may have slightly different names in that program) and report those values to me.
Send me a report of those tests. [/ol]
I know it’s a lot to ask, but I cannot duplicate you error here because I do not have your other code nor your specific BME280 chip.
TemeratureFine is 116906
RawPressureADC is 524288
dig_P1 is 37510
dig_P2 is -10879
dig_P3 is 3024
dig_P4 is 10736
dig_P5 is -75
dig_P6 is -7
dig_P7 is 9900
dig_P8 is -10230
dig_P9 is 4285
@ scardinale -
RawPressureADC Yours: 524288 (0x80000) Mine 256586 (0x3EA4A)
All other valies were reasonably close to mine.
I have compared your results with my results. I must say that I see only one glaring error. Your value of RawPressureADC is 524288 (decimal) or 0x80000. If you consult Table 18 in the documentation for the BME280 chip, you will find the following:
register 0xF9, Name: press_xlsb, Valid bits: [7:4], Reset value: 0x00
register 0xF8, Name: press_lsb, Valid bits: [7:0], Reset value: 0x00
register 0xF7, Name: press_msb, Valid bits: [7:0], Reset value: 0x80
When parsing the registers for RawPressureADC, the driver reads the registers in the following order:
0xF7, 0xF8, 0xF9
In your case:
0x80, 0x00 0x00 = 0x800000
Since the last four bits of register 0xF9 are invalid, the value of 0x800000 is shifted right 4 times for a final value of 0x80000. This is 524288 decimal. Thus, when the pressure registers 0xF7 - 0xF9 read 524288, it means that the BME280 pressure registers are returning their reset values. I can only assume that this happens because these registers have not been updated after the Measure command. It seems that the measurements for temperature and relative humidity are copied to the output registers, but not the values for pressure. I don’t think that you have complained that the temperature or RH values are incorrect.
My driver code checks the status register and waits to read the result registers until such a time as the status register at 0xF3 does not have bit 3 (the measuring bit) or bit 0 (the im_update bit) set.
The BME280 documentation says this about the two bits in the status register:
Bit 3
Automatically set to ‘1’ whenever a conversion is running and back to ‘0’ when the results have been transferred to the data registers.
Bit 0
Automatically set to ‘1’ when the NVM (non-volatile memory) data are being copied to image registers and back to ‘0’ when the copying is done. The data are copied at power-on-reset and before every conversion.
The result you are seeing here makes me think that it may be necessary for my code to wait after commanding a measurement for the status register to read other than 0x00 (other than Idle), and then to read 0x00 (Idle) instead of just checking immediately that the status register reads 0x00.
Could you go to the Measure method and add the following line after TriggerMeasurements():
// Add the following line
while (GetStatus() == StatusFlags.Idle) Thread.Sleep(100);
// place the above this existing code:
while (GetStatus() != StatusFlags.Idle) Thread.Sleep(100);
I think the above change will insure a wait for the status to change to some form of busy, followed by a wait for the status to change back to idle. This may resolve the issue with my driver on your hardware.
If this is the case, I will update the driver.
Adding this code causes it to hang while waiting for the GetStatus to become idle.
@ scardinale -
I want to thank you for having the time and patience you’ve displayed assisting me in trying to resolve the issue you’ve reported. I think I am making progress towards a resolution. I appreciate all that you have been willing to do for me.
From your last post, it would appear that your status register is never going to idle. This is a clear indication to me that the other driver you are using is setting up the mode bits and/or the config bits so that the BME280 chip is working in the Normal, not Forced mode. This would mean that in normal mode, the BME280 is continually sampling and therefore always measuring, never idle. I tried the code change I sent to you previously, regarding the status checking, and it worked fine on my Diymall BME280 breakout board, which is working in Forced mode…
In another message you sent to me you said that my driver would work if you first set up the BME280 chip with the other driver you have then invoked my code.
My driver code depends upon the fact that the config register (0xF5) is set to 0x00, which is the power-on default. My driver makes the assumption that when I construct a BME280Device object, it has previously been left in the power-on default state. I think, especially because of the experience you relate, that assuming a power-on default state is a very bad assumption for my driver. Accordingly, I am going to make a new release for you to test that resets the BME280 chip before performing any measurement. This will place your BME280 chip into Forced mode when you call measure, which is the only mode supported by my driver code.
I’m also wondering about the frequency that you’ve selected for creating the BME280Device object. Have you changed the frequency from my default of 100 kHz? This could explain some timing differences which would cause my driver to see the registers for the raw pressure at the reset value.
Look for a patched driver here in this thread soon.
This action may disrupt the operation of the BME280 chip on the other software you are running, perhaps concurrently. I’ll post a new version of the driver in this thread soon, and hopefully, you can test it.
@ scardinale -
Revision 2 test with chip reset before measuring:
using System.Collections;
/// Revision 2 With reset before measure.
namespace Cobra3AWS
    /// <summary>
    /// <para>Class BME280Device sets up the Bosch BME28 temperature/pressure/humidity sensor for a </para>
    /// <para>weather monitoring application.  Other modes are possible but not covered by this class.</para>
    /// <para>See the documentation for the Bosch BME280 devuce.</para>
    /// <para>.</para>
    /// <para>Sensor mode:  forced mode, 1 sample per minute</para>
    /// <para>Oversampling settings:  pressure x 1, temperature x 1, humidity x 1</para>
    /// <para>IIR filter settings:  filter off</para>
    /// <para>.</para>
    /// <para>Performance for weather setting:</para>
    /// <para>    Current consumption: 0.16uA</para>
    /// <para>    RMS Noise:           3.3Pa/30cm, 0.07% RH</para>
    /// <para>    Data oputput rate:   1/60 secs</para>
    /// </summary>
    public class BME280Device : IDisposable
        #region StatusFlags enumeration (PUBLIC)
        /// <summary>
        /// <para>Enumeration StatusFlags represents the states of statis that the BME280</para>
        /// <para>device reports.</para>
        /// </summary>
        [Flags]
        public enum StatusFlags { Idle = 0, NVRamUpdate = 1, Measuring = 8 };
        #endregion
        #region Constants
        /// <summary>kFeetIncrementForMillibarLookup = 200</summary>
        private const int kFeetIncrementForMillibarLookup = 200;
        /// <summary>kMetersPerFoot =  0.3048</summary>
        private const double kMetersPerFoot =  0.3048F;
        /// <summary>kFeetPerMeter = 1.0F / kMetersPerFoot</summary>
        private const double kFeetPerMeter = 1.0F / kMetersPerFoot;
        /// <summary>kMinAltitudeMeters = -308F</summary>
        private const double kMinAltitudeMeters = -308F;
        /// <summary>kMaxAltitudeMeters = 3080F</summary>
        private const double kMaxAltitudeMeters = 3080F;
        /// <summary>kMinAltitudeFeet = -1000F</summary>
        private const double kMinAltitudeFeet = -1000F;
        /// <summary>kMaxAltitudeFeet = 10000F</summary>
        private const double kMaxAltitudeFeet = 10000F;
        /// <summary>kDefaltAltitudeFeet = 0F</summary>
        private const double kDefaltAltitudeFeet = 0F;
        // http://www.engineeringtoolbox.com/barometers-elevation-compensation-d_1812.html
        private readonly short[] kMillibarCorrections = new short[]  {
            /* Altitude    Corrextion */
            /*-1000 */     -37,
            /*-800*/       -30,
            /*-600 */      -22,
            /*-400 */      -15,
            /*-200 */       -7,
            /* 0 */          0,
            /* 200 */        7,
            /* 400 */       15,
            /* 600 */       22,
            /* 800 */       29,
            /* 1000 */      36,
            /* 1200 */      43,
            /* 1400 */      50,
            /* 1600 */      57,
            /* 1800 */      64,
            /* 2000 */      71,
            /* 2200 */      78,
            /* 2400 */      85,
            /* 2600 */      92,
            /* 2800 */      98,
            /* 3000 */     105,
            /* 3200 */     112,
            /* 3400 */     118,
            /* 3600 */     125,
            /* 3800 */     132,
            /* 4000 */     138,
            /* 4200 */     145,
            /* 4400 */     151,
            /* 4600 */     157,
            /* 4800 */     164,
            /* 5000 */     170,
            /* 5200 */     176,
            /* 5400 */     183,
            /* 5600 */     189,
            /* 5800 */     195,
            /* 6000 */     201,
            /* 6200 */     207,
            /* 6400 */     213,
            /* 6600 */     219,
            /* 6800 */     225,
            /* 7000 */     231,
            /* 7200 */     237,
            /* 7400 */     243,
            /* 7600 */     249,
            /* 7800 */     255,
            /* 8000 */     261,
            /* 8200 */     266,
            /* 8400 */     272,
            /* 8600 */     278,
            /* 8800 */     283,
            /* 9000 */     289,
            /* 9200 */     295,
            /* 9400 */     300,
            /* 9600 */     306,
            /* 9800 */     311,
            /*10000 */     316 };
        /// <summary>kKpaToInchesHg = 0.2953F</summary>
        private const float kKpaToInchesHg = 0.2953F;
        /// <summary>kMillibarsPerPa = 100F</summary>
        private const float kMillibarsPerPa = 100F;
        /// <summary>kMillibarsPerKpa = 10F</summary>
        private const float kMillibarsPerKpa = 0.1F;
        /// <summary>kRegisterIDAddress = 0xD0</summary>
        private const byte kRegisterIDAddress = 0xD0;
        /// <summary>kValidIDByte = 0x60</summary>
        private const byte kValidIDByte = 0x60;
        /// <summary>kRegisterReset = 0xF0</summary>
        private const byte kRegisterReset = 0xF0;
        /// <summary>kResetValue = 0xB6</summary>
        private const byte kResetValue = 0xB6;
        /// <summary>kRegisterHumidityControl = 0xF2</summary>
        private const byte kRegisterHumidityControl = 0xF2;
        /// <summary>kHumidityOversample1X = 0x01</summary>
        private const byte kHumidityOversample1X = 0x01;
        /// <summary>kHumidityControlValue = kHumidityOversample1X</summary>
        private const byte kHumidityControlValue = kHumidityOversample1X;
        /// <summary>kRegisterStatus = 0xF3</summary>
        private const byte kRegisterStatus = 0xF3;
        /// <summary>byte kStatusMask = 0x09</summary>
        private const byte kStatusMask = 0x09;
        /// <summary>kRegisterMeasurementControl = 0xF4</summary>
        private const byte kRegisterMeasurementControl = 0xF4;
        // Temperature Oversampling
        // 0   0   0                    No sample
        // 0   0   1                    x1
        // 0   1   0                    x2
        // 0   1   1                    x4
        // 1   0   0                    x8
        // 1   0   1                    x16
        // 1   1   1                    x16 <- not a mustake
        // Pressure Oversamoliuing
        //              0   0   0                    No sample
        //              0   0   1                    x1
        //              0   1   0                    x2
        //              0   1   1                    x4
        //              1   0   0                    x8
        //              1   0   1                    x16
        // Mode
        //                          0    0           Sleep mode
        //                          0    1           Forced mode
        //                          1    0           Forced mode <- not a mistake
        //                          1    1           Normal mode
        // 0   0   1   0   0   1    0    1           Temperature x1, pressure x 1, forced mode (weather monitoring)
        /// <summary>kRegisterConfig = 0xF5</summary>
        private const byte kRegisterConfig = 0xF5;
        /// <summary>kWeatherMonitoringConfig = 0x25</summary>
        private const byte kWeatherMonitoringConfig = 0x25;
        /// <summary>kConfigData = 0x00</summary>
        private const byte kConfigData = 0x00;  // Default for weather monitoring.
        /// <summary>kRegisterADCDataStart = 0xF7</summary>
        private const byte kRegisterADCDataStart = 0xF7;
        /// <summary>kRegisterAdcDataEnd = 0xFE</summary>
        private const byte kRegisterAdcDataEnd = 0xFE;
        /// <summary>kADCDataCount = kRegisterAdcDataEnd - kRegisterADCDataStart + 1</summary>
        private const byte kADCDataCount = kRegisterAdcDataEnd - kRegisterADCDataStart + 1;
        /// <summary>kRegisterCalDataSection88Start = 0x88</summary>
        private const byte kRegisterCalDataSection88Start = 0x88;
        /// <summary>kRegisterCalDataSection88End = 0xA1</summary>
        private const byte kRegisterCalDataSection88End = 0xA1;
        /// <summary>kCalDataSection88Length = kRegisterCalDataSection88End - kRegisterCalDataSection88Start +1</summary>
        private const byte kCalDataSection88Length = kRegisterCalDataSection88End - kRegisterCalDataSection88Start + 1;
        /// <summary>kRegisterCalDataSectionE1Start = 0xE1</summary>
        private const byte kRegisterCalDataSectionE1Start = 0xE1;
        /// <summary>kRegisterCalDataSectionE1End = 0xE7</summary>
        private const byte kRegisterCalDataSectionE1End = 0xE7;
        /// <summary>kCalDataSectionE1Length = kRegisterCalDataSectionE1End - kRegisterCalDataSectionE1Start + 1</summary>
        private const byte kCalDataSectionE1Length = kRegisterCalDataSectionE1End - kRegisterCalDataSectionE1Start + 1; // 6 +1
        /// <summary>kMaxFrequencyKhz = 400</summary>
        private const ushort kMaxFrequencyKhz = 400;
        /// <summary>kMinFrequencyKhz = 10</summary>
        private const ushort kMinFrequencyKhz = 10;
        /// <summary>kminValidAddress = 0x76</summary>
        private const ushort kminValidAddress = 0x76;
        /// <summary>kMaxValidAddress = 0x77</summary>
        private const ushort kMaxValidAddress = 0x77;
        /// <summary>kMaxExecuteTry = 3</summary>
        private const int kMaxExecuteTry = 3;
        /// <summary>kI2cBusTransactionFailed = "I2C bus transaction failed."</summary>
        private const string kI2cBusTransactionFailed = "I2C bus transaction failed.";
        #endregion
        #region AltitudeInFeet property (PUBLIC)
        /// <summary>
        /// Property AltitudeInFeet sets the altitude of the BME280 Device in feet.
        /// </summary>
        public double AltitudeInFeet
            get { return _altitudeInFeet; }
            set
                if (value <  kMinAltitudeFeet || value > kMaxAltitudeFeet)
                    throw new BME280Exception (
                        "Altitude (feet) is outside range of " +
                        kMinAltitudeFeet.ToString() +
                        " to " +
                        kMinAltitudeFeet.ToString() + ".");
                _altitudeInFeet = value;
                _altitudeInMeters = _altitudeInFeet * kMetersPerFoot;
        #endregion
        #region AltitudeInMeters property (PUBLIC)
        /// <summary>
        /// Property AltitudeInMeters gets/sets the altitude (in meters) of the BME280 Device.
        /// </summary>
        public double AltitudeInMeters
            get { return _altitudeInMeters; }
            set
                if (value < kMinAltitudeMeters || value > kMaxAltitudeMeters)
                    throw new BME280Exception(
                        "Altitude (meters) is outside range of " +
                        kMinAltitudeMeters.ToString() +
                        " to " +
                        kMinAltitudeMeters.ToString() + ".");
                _altitudeInMeters = value;
                _altitudeInFeet = _altitudeInMeters * kFeetPerMeter;
        #endregion
        #region RawTemperatureADC property (private)
        /// <summary>
        /// <para>Property RawTemperatureADC gets/sets the internal representation of the </para>
        /// <para>temperature data stored at registers 0xFA, oxFB, and 0xFC in the BME280</para>
        /// <para>device.</para>
        /// <para>.</para>
        /// <para>o Register 0xFA (MSB) bits [7:0] contain bits [19:12] of RawTemperatureADC</para>
        /// <para>o Register 0xFB (LSB) bits [7:0] contain bits [11:4] of RawTemperatureADC</para>
        /// <para>o Register 0xFC (XLSB) bits [7:4] contian bits [3:0] of RawTemperatureADC</para>
        /// </summary>
        private Int32 RawTemperatureADC { get; set; }
        #endregion
        #region RawPressureADC property (private)
        /// <summary>
        /// <para>Property RawPressureADC gets/sets the internal representation of the </para>
        /// <para>pressure data stored at registers 0xf7, 0xF8, and 0xF9 in the BMD280</para>
        /// <para>.</para>
        /// <para>o Register 0xF7 (MSB) bits [7:0] contain bits [19:12] of RawPressureADC</para>
        /// <para>o Register 0xF8 (LSB) bits [7:0] contain bits [11:4] of RawPressureADC</para>
        /// <para>o Register 0xF9 (XLSB) bits [7:4] contian bits [3:0] of RawPressureADC</para>
        /// </summary>
        private Int32 RawPressureADC { get; set; }
        #endregion
        #region RawHumidityADC property (private)
        /// <summary>
        /// <para>Property RawHumidityADC gets/sets the internal representation of the </para>
        /// <para>humidity data stored at registers 0xf7, 0xF8, and 0xF9 in the BMD280</para>
        /// <para>.</para>
        /// <para>o Register 0xFD (MSB) bits [7:0] contain bits [15:8] of RawHumidityADC</para>
        /// <para>o Register 0xFE (LSB) bits [7:0] contain bits [7:0] of RawHumidityADC</para>
        /// </summary>
        private Int32 RawHumidityADC { get; set; }
        #endregion
        #region Device property (private)
        /// <summary>
        /// <para>Property Device represents the underlying I2CDevice that represents the BME280Device </para>
        /// <para>object.</para>
        /// </summary>
        private I2CDevice Device { get; set; }
        #endregion
        #region TemperatureFine property (private)
        /// <summary>
        /// <para>Property TemperatureFine represents a temperature value used in the calculations </para>
        /// <para>pf pressure and humidity.</para>
        /// </summary>
        private int TemperatureFine { get; set; }
        #endregion
        #region ReportPressureInMillibars property (PUBLIC)
        /// <summary>
        /// <para>Property ReportPressureInMillibars gets/sets the pressure reporting mode. Value </para>
        /// <para>true indicates a millibar unit selection; otherwise inches of Hg unit selection.</para>
        /// </summary>
        public bool ReportPressureInMillibars { get; set; }
        #endregion
        #region ReportTemperatureInCentigrade property (PUBLIC)
        /// <summary>
        /// <para>Property ReportTemperatureInCentigrade gets/sets the temperature reporting mode. Value</para>
        /// <para>true represents degrees Centigrade units; otherwise degrees Farenheit unit selection.</para>
        /// </summary>
        public bool ReportTemperatureInCentigrade { get; set; }
        #endregion
        #region Member Variables
        ushort dig_T1;
        short dig_T2, dig_T3;
        ushort dig_P1;
        short dig_P2, dig_P3, dig_P4, dig_P5, dig_P6, dig_P7, dig_P8, dig_P9;
        byte dig_H1;
        short dig_H2;
        byte dig_H3;
        short dig_H4, dig_H5;
        sbyte dig_H6;
        private double _altitudeInFeet;
        private double _altitudeInMeters;
        #endregion
        #region #ctor (PUBLIC)
        /// <summary>
        /// <para>Constructor BME280Device creates a BME280Device object that represents a single</para>
        /// <para>Bosch BME280 environmental sensor.</para>
        /// <para>.</para>
        /// <para>The constructor does the following:</para>
        /// <para>o Validates the 7-bit slave address</para>
        /// <para>o Validates the clock frequency</para>
        /// <para>o Creates the underlying I2CDevice object</para>
        /// <para>o Communicates with the device to validate the device ID</para>
        /// <para>o Gets and stores the device unique calibration data for this BME280Device</para>
        /// </summary>
        /// <param name="slaveAddress">The 7-bit slave address</param>
        /// <param name="frequencykHz">The I2C communication frequency in kHz</param>
        /// <exception cref="BME280Exception"></exception>
        public BME280Device(ushort slaveAddress, int frequencykHz = 100)
            Device = null;
            if (slaveAddress < kminValidAddress || slaveAddress > kMaxValidAddress)
                throw new BME280Exception("Slave address out of range of 0x76-0x77.");
            if (frequencykHz < kMinFrequencyKhz || frequencykHz > kMaxFrequencyKhz)
                throw new BME280Exception("Clock frequency out of range.");
            try { Device = new I2CDevice(new I2CDevice.Configuration(slaveAddress, frequencykHz)); }
            catch (Exception ex) { throw new BME280Exception("I2CDevice constructor failed.", ex); }
            // Validate that this is a BME280 chip
            ValidateChipID();
            // Make a one-time read of the calibration data
            GetCalibrationData();
            // Initialize the altitude (through feet)
            AltitudeInFeet = 0F;
            // Initialize the reporting to report pressure in millibars and temperature in Centigrade
            ReportPressureInMillibars = true;
            ReportTemperatureInCentigrade = true;
        #endregion
        #region ValidateChipID method (private)
        /// <summary>
        /// <para>Method ValidateChipID validates that the BME280 device is </para>
        /// <para>present, responding, and reports the correct chip ID. </para>
        /// </summary>
        private void ValidateChipID()
            byte[] chipId = { 0x00 };
            byte[] chipIDRegister = { kRegisterIDAddress };
            I2CDevice.I2CTransaction[] transactions =
                // Write the chipID register
                I2CDevice.CreateWriteTransaction(chipIDRegister),
                // Read the 1-byte chipID
                I2CDevice.CreateReadTransaction(chipId)
            try { Device.Transact(transactions, 1000); }
            catch (Exception ex) { throw new BME280Exception(kI2cBusTransactionFailed, ex); }
            if (chipId[0] != kValidIDByte)
                throw new BME280Exception("Invalid BME280 chip ID.");
        #endregion
        #region GetCalibrationData method (private)
        /// <summary>
        /// <para>Method GetCalibrationData gets the device-unique factory-set calibration data</para>
        /// <para>for values for temperature, pressure, and humidity.</para>
        /// <para>.</para>
        /// <para>The calibration values are read-only and do not change for the life of the device.</para>
        /// </summary>
        /// <remarks>
        /// <para>The calibration values are stored as member variables in the BME280Device class.</para>
        /// </remarks>
        private void GetCalibrationData()
            byte[] calDataPart1Start = { kRegisterCalDataSection88Start };
            byte[] calDataPart2Start = { kRegisterCalDataSectionE1Start };
            byte[] calDataPart1 = new Byte[kCalDataSection88Length];
            byte[] calDataPart2 = new Byte[kCalDataSectionE1Length];
                // Set register start address for a read at calDataPart1Start
                I2CDevice.CreateWriteTransaction(calDataPart1Start),
                // Read sizeof(calDataPart1)
                I2CDevice.CreateReadTransaction(calDataPart1),
                // Set register start address for a read at calDataPart2Start
                I2CDevice.CreateWriteTransaction(calDataPart2Start),
                // Read sizeof(calDataPart2)
                I2CDevice.CreateReadTransaction(calDataPart2)
            try { Device.Transact(transactions, 2000); }
            // Initialize index for the start of the calDataPart1 buffer
            int index = 0;
            // Capture temperature calibration variables
            dig_T1 = calDataPart1.ExtractUShort(ref index);  // data at register 0x88[7:0]/0x89[15:8] to dig_T1
            dig_T2 = calDataPart1.ExtractShort(ref index);   // data at register 0x8A[7:0]/0x8B[15:8] to dig_T2
            dig_T3 = calDataPart1.ExtractShort(ref index);   // data at register 0x8C[7:0]/0x8D[15:8] to dig_T2
            // Capture pressure calibration variables
            dig_P1 = calDataPart1.ExtractUShort(ref index);  // data at register 0x8E[7:0]/0x8F[15:8] to dig_P1
            dig_P2 = calDataPart1.ExtractShort(ref index);   // data at register 0x90[7:0]/0x91[15:8] to dig_P2
            dig_P3 = calDataPart1.ExtractShort(ref index);   // data at register 0x92[7:0]/0x93[15:8] to dig_P3
            dig_P4 = calDataPart1.ExtractShort(ref index);   // data at register 0x94[7:0]/0x95[15:8] to dig_P4
            dig_P5 = calDataPart1.ExtractShort(ref index);   // data at register 0x96[7:0]/0x97[15:8] to dig_P5
            dig_P6 = calDataPart1.ExtractShort(ref index);   // data at register 0x98[7:0]/0x99[15:8] to dig_P6
            dig_P7 = calDataPart1.ExtractShort(ref index);   // data at register 0x9A[7:0]/0x9B[15:8] to dig_P7
            dig_P8 = calDataPart1.ExtractShort(ref index);   // data at register 0x9C[7:0]/0x9D[15:8] to dig_P8
            dig_P9 = calDataPart1.ExtractShort(ref index);   // data at register 0x9E[7:0]/0x9F[15:8] to dig_P9
            index += sizeof(byte);                           // skip the data at register 0xA0 (unused)
            // Capture humidity calibration variables
            dig_H1 = calDataPart1[index++];                  // data at register 0xA1[7:0]
            // reset the index to use the calDataPart2 buffer
            index = 0;                                          // reseet index for calDataPart2 buffer
            dig_H2 = calDataPart2.ExtractShort(ref index);      // data at register 0xE1[7:0]/0xE2[15:8]
            dig_H3 = calDataPart2[index++];                     // data at register 0xE3[7:0]
            // Data at registers 0xE4-0xE6 are spread between two calibration
            // variables so get the values separately
            var E4 = (UInt32)calDataPart2[index++];            // data at register 0xE4[7:0]
            var E5 = (UInt32)calDataPart2[index++];            // data at register 0xE5[7:0]
            var E6 = (UInt32)calDataPart2[index++];            // data at register 0xE6[7:0]
            // 12-bit Calibration variable dig_H4 exists in the following bytes and bits:
            // E4 [11:4] and E5[0:3]
            // Mapping:
            // 15   14   13   12   11   10   09   08   07   06   06   04   03   02   01   00
            // X    X    X    X    E4-7 E4-6 E4-5 E4-4 E4-3 E4-2 E4-1 E4-0 E5-3 E5-2 E5-1 E5-0
            dig_H4 = (short)(E4 << 4);                        // E4[7:0] to dig_H4[11:4]
            dig_H4 |= (short)(E5 & 0x0F);                     // E5[3:0] to dig_H4[3:0]
            // 12-bit Calibration variable dig_H5 exists in the in the following bytes and bits:
            // TODO
            // E5[7:4] and E6 [11:4] comprise the dig_h4 variable
            // Mapping:
            // X    X    X    X    E6-7 E6-6 E6-5 E6-4 E6-3 E6-2 E5-1 E6-0 E5-7 E5-6 E5-5 E5-4
            dig_H5 = (short)(E6 << 4);                       // E6[7:0] to dig_H5[11:4]
            dig_H5 |= (short)(E5 >> 4);                      // E5[7:4] to dig_H5[3:0]
            dig_H6 = (sbyte)calDataPart2[index++];           // data at register 0xE7[7:0] to dig_H6
        #endregion
        #region GetRawADCData method (private)
        /// <summary>
        /// <para>Method GetRawADCData gets the raw data from the device int </para>
        /// <para>the RawPressureADC, RawTemperatureADC, and the RawHumidityADC</para>
        /// <para>properties.</para>
        /// </summary>
        private void GetRawADCData()
            // The raw data for pressure, temperature and humidity are mapped
            // into the following BME 280 registers
            // 0xF7 pressure      MSB[7:0]
            // 0xF8 pressure      LSB[7:0]
            // 0xF9 pressure     XLSB[7:4] bits [3:0] are zero
            // 0xFA temperature   MSB[7:0]
            // 0xFB temperature   LSB[7:0]
            // 0xFC temperature  XLSB[7:4] bits [3:0] are zero
            // 0xFD humidity      MSB[7:0]
            // 0xFE humitidy      LSB[7:0]
            // Raw temperature and raw pressure values are 20 bit precision in 24 bits
            // Raw temperatiure and raw pressure values must be shifted right 4 places
            // after reading and converting from big endian to little endian.
            // Raw humidity values are 16 bit precision.
            // Buffer for command (register address)
            byte[] rawDataStart = { kRegisterADCDataStart };
            // Buffer for data
            byte[] rawDataBuffer = new Byte[kADCDataCount];
            // Create the I2C transaction sequence
                // Write the register start address for a read at kRegisterADCDataStart
                I2CDevice.CreateWriteTransaction(rawDataStart),
                // Read rawDataBuffer.Length bytes
                I2CDevice.CreateReadTransaction(rawDataBuffer),
            // Get raw pressure
            int index = 0;
            // Read 3 bytes, convert to little endian and shift result right by 4
            RawPressureADC = rawDataBuffer.ExtractIntFromBigEndianBuffer(ref index, 3, 4);
            // Get raw temperature
            RawTemperatureADC = rawDataBuffer.ExtractIntFromBigEndianBuffer(ref index, 3, 4);
            // Get raw humidity
            // Read 2 bytes, convert to little endian do not shift result
            RawHumidityADC = rawDataBuffer.ExtractIntFromBigEndianBuffer(ref index, 2, 0);
        #endregion
        #region Measure method (PUBLIC)
        /// <summary>
        /// <para>Method Measure returns the temperature, pressure, and relitive humidity percent.</para>
        /// <para>The units of the temperature and pressure measurement depend on the settings of </para>
        /// <para>the ReportPressureInMillibars property and the ReportTemperatureInCentigrade property.</para>
        /// <para>The options for pressure consist of Millibars or inches Hg.  The options for temperature</para>
        /// <para>consist of Centigrade or Farenheight.</para>
        /// </summary>
        /// <param name="temperature">The returned temperature value</param>
        /// <param name="pressure">The returned pressure value</param>
        /// <param name="relativeHumidityPercent">The returned humidity value</param>
        public void Measure(out double temperature, out double pressure, out double relativeHumidityPercent)
            TriggerMeasurements();
            GetRawADCData();
            temperature = ReportTemperatureInCentigrade ?
                GetCompensatedTemperatureC() :
                GetCompensatedTemperatureF();
            pressure = ReportPressureInMillibars ?
                GetCompensatedPressureInMillibars() :
                GetCompensatedPressureInInchesHg();
            relativeHumidityPercent = GetCompensatedHumidity();
        #endregion
        #region TriggerMeasurements method (private)
        /// <summary>
        /// <para>Method TriggerMeasurements configures the BME280 device to make a forced single</para>
        /// <para>measurement cycle for temperature, pressure and humidity, suitable for weather</para>
        /// <para>monitoring. The measurements results are posted by the DME280 device from shadow</para>
        /// <para>registers to the raw ADC registers readable by the I2C interface.</para>
        /// </summary>
        private void TriggerMeasurements()
            byte[] reset = { kRegisterReset, kResetValue };
            byte[] config = { kRegisterConfig, kConfigData };
            byte[] ctrl_hum = { kRegisterHumidityControl, kHumidityOversample1X };
            byte[] ctrl_meas = { kRegisterMeasurementControl, kWeatherMonitoringConfig };
                // Reset the device
                I2CDevice.CreateWriteTransaction(reset),
                // Write the register kRegisterConfig to set confiuguration
                // 1 byte transfer
                I2CDevice.CreateWriteTransaction(config),
                // Write the register kRegisterHumidityControl to set humidty oversampling
                // 1 byte transfer
                I2CDevice.CreateWriteTransaction(ctrl_hum),
                // Write the register kRegisterMeasurementControl to set pressure and temperature oversampling and forced mode
                // 1 byte transfer
                I2CDevice.CreateWriteTransaction(ctrl_meas),
        #endregion
        #region GetStatus method (private)
        /// <summary>
        /// <para>Method GetStatus reads the BME280 device statis register and returns the status as a </para>
        /// <para>StatusFlags enumeration.</para>
        /// </summary>
        /// <returns>
        /// </returns>
        private StatusFlags GetStatus()
            byte[] statusStart = { kRegisterStatus };
            byte[] status = { 0xFF };
                // Write the register start address for a read at kRegisterStatus
                I2CDevice.CreateWriteTransaction(statusStart),
                // Read the value of the status
                I2CDevice.CreateReadTransaction(status),
            status[0] = (byte)(status[0] & kStatusMask);
            return (StatusFlags)status[0];
        #endregion
        #region Dispose method (PUBLIC)
        /// <summary>
        /// <para>Method Dispose disposes the underlying I2C device, Device.</para>
        /// </summary>
        public void Dispose()
            if (Device != null) Device.Dispose();
            Device = null;
        #endregion
        #region GetCompensatedTemperatureF method (private)
        /// <summary>
        /// <para>Method GetCompensatedTemperatureF returns the compensated temperature</para>
        /// <para>in Degrees Farenheit.</para>
        /// </summary>
        /// <returns>
        /// </returns>
        private double GetCompensatedTemperatureF()
            var temp = (GetCompensatedTemperatureC() * 9F / 5F) + 32F;
            // scale to nearest .1 unit
            temp = (double)((int)(temp * 10)) / ((double)10);
            return temp;
        #endregion
        #region GetCompensatedTemperatureC method (private)
        /// <summary>
        /// <para>Method GetCompensatedTemperatureC uses the dig_T* temperature compensation factors</para>
        /// <para>and the RawTemperatureADC value to return a compensated temperature in Centigrade.</para>
        /// <para>. </para>
        /// <para>It also sets the TemperatureFine property used in the calculation of pressure and humidity.</para>
        /// </summary>
        /// <returns>
        /// </returns>
        /// <remarks>
        /// <para>Always call GetCompensatedTemperatureC before calling any method that returns pressure</para>
        /// <para>or humidity.</para>
        /// </remarks>
        private double GetCompensatedTemperatureC()
            double var1, var2, temp;
            var1 = (((double)RawTemperatureADC) / 16384.0 - ((double)dig_T1) / 1024.0) * ((double)dig_T2);
            var2 = ((((double)RawTemperatureADC) / 131072.0 - ((double)dig_T1) / 8192.0) *
                (((double)RawTemperatureADC) / 131072.0 - ((double)dig_T1) / 8192.0)) * ((double)dig_T3);
            TemperatureFine = (int)(var1 + var2);
            temp = (var1 + var2) / 5120.0;
            return temp;
        #endregion
        #region GetCompensatedPressureInPa method (private)
        /// <summary>
        /// <para>Method GetCompensatedPressureInPa uses the dig_P* compensation factors, the TemperaturFine</para>
        /// <para>property value, and the RawPressureADC value to calculate an return a compensated pressure </para>
        /// <para>in Pa.</para>
        /// </summary>
        /// <returns>
        /// </returns>
        private double GetCompensatedPressureInPa()
            double var1, var2, p;
            var1 = ((double)TemperatureFine / 2.0) - 64000.0;
            var2 = var1 * var1 * ((double)dig_P6) / 32768.0;
            var2 = var2 + var1 * ((double)dig_P5) * 2.0;
            var2 = (var2 / 4.0) + (((double)dig_P4) * 65536.0);
            var1 = (((double)dig_P3) * var1 * var1 / 524288.0 + ((double)dig_P2) * var1) / 524288.0;
            var1 = (1.0 + var1 / 32768.0) * ((double)dig_P1);
            if (var1 == 0.0) return 0;
            p = 1048576.0 - (double)RawPressureADC;
            p = (p - (var2 / 4096.0)) * 6250.0 / var1;
            var1 = ((double)dig_P9) * p * p / 2147483648.0;
            var2 = p * ((double)dig_P8) / 32768.0;
            p = p + (var1 + var2 + ((double)dig_P7)) / 16.0;
            return p;
        #endregion
        #region GetCompensatedPressureInMillibars method (private)
        /// <summary>
        /// <para>Method GetCompensatedPressureInMillibars returns the compensated pressure</para>
        /// <para>in millibars.</para>
        /// </summary>
        /// <returns>
        /// </returns>
        private double GetCompensatedPressureInMillibars()
            var result = GetCompensatedPressureInPa() / kMillibarsPerPa;
            result += (double)GetMillibarCorrectionForAltitude();
            // Scale to nearest .01
            result = (double)((int)(result * 100)) / ((double)100);
            return result;
        #endregion
        #region GetCompensatedPressureInInchesHg method (private)
        /// <summary>
        /// <para>Method GetCompensatedPressureInInchesHg returns the compensated pressure</para>
        /// <para>im mm of Hg/</para>
        /// </summary>
        /// <returns>
        /// </returns>
        double GetCompensatedPressureInInchesHg()
            var result = GetCompensatedPressureInMillibars() * kMillibarsPerKpa * kKpaToInchesHg;
            // Scake to nearest .01
            return result;
        #endregion
        #region GetCompensatedHumidity method (private)
        /// <summary>
        /// <para>Method GetCompensatedHumidity uses the dig_H* compensation parameters, the TemperatureFine</para>
        /// <para>property value and the RawHumidityADC value to calculate and return a compensated relative </para>
        /// <para>humidity. </para>
        /// </summary>
        /// <returns>
        /// </returns>
        double GetCompensatedHumidity()
            double var_H;
            var_H = (((double)TemperatureFine) - 76800.0);
            var_H = (RawHumidityADC - (((double)dig_H4) * 64.0 +
                                       ((double)dig_H5) / 16384.0 * var_H)) *
                (((double)dig_H2) / 65536.0 * (1.0 + ((double)dig_H6) / 67108864.0 * var_H *
                (1.0 + ((double)dig_H3) / 67108864.0 * var_H)));
            var_H = var_H * (1.0 - ((double)dig_H1) * var_H / 524288.0);
            if (var_H > 100.0) var_H = 100.0;
            else if (var_H < 0.0) var_H = 0.0;
            // Scale to nearest .1
            var_H = (double)((int)(var_H *10))/((double)10);
            return var_H;
        #endregion
        private int GetMillibarCorrectionForAltitude()
            // Shift to positive area.
            var altitudeInFeet = (int)AltitudeInFeet;
            var negativeLookupOffset = (int)(kMinAltitudeFeet);
            altitudeInFeet += System.Math.Abs(negativeLookupOffset);
            var altitudeLookupIndex = altitudeInFeet/kFeetIncrementForMillibarLookup;
            var wholeMillibars = kMillibarCorrections[altitudeLookupIndex];
            if (altitudeLookupIndex < kMillibarCorrections.Length-1)
                var extrapolationDistance = altitudeInFeet % kFeetIncrementForMillibarLookup;
                var nextWholeMillibars = kMillibarCorrections[altitudeLookupIndex + 1];
                var diffMillibars = (double)nextWholeMillibars - (double)wholeMillibars;
                diffMillibars = (double)extrapolationDistance / (double)kFeetIncrementForMillibarLookup * diffMillibars;
                wholeMillibars += (short)System.Math.Round(diffMillibars);
            return wholeMillibars;
    /// <summary>
    /// A BME280 specific exception.
    /// </summary>
    public class BME280Exception : Exception
        public BME280Exception() { }
        public BME280Exception(string message) : base(message) {}
        public BME280Exception(string message, Exception inner) : base(message, inner) {}
    public class I2CException : Exception
        public I2CException() { }
        public I2CException(string message) : base(message) { }
        public I2CException(string message, Exception inner) : base(message, inner) { }
    public static class I2DeviceExtensions
        /// <summary>
        /// Object I2CBusLock consists of a locking object for the I2C Bus.
        /// </summary>
        private static object I2CBusLock = new object();
        #region Transact extension method of I2CDevice (PUBLIC)
        /// <summary>
        /// <para>Transact extension method of I2CDevice accepts I2C trnasactions and a timeout</para>
        /// <para>value and calls upon I2CDevice to execute the I2C bus transactions in a thread</para>
        /// <para>save manner.</para>
        /// </summary>
        /// <param name="this">blins this parameter</param>
        /// <param name="transactions">An array of I2CTransaction to perform</param>
        /// <param name="timeout">A timeout value to perform the transactions</param>
        /// <exception cref="I2CException"></exception>
        public static void Transact(
            this I2CDevice @ this,
            I2CDevice.I2CTransaction[] transactions,
            int timeout)
            int bytesToTransfer = 0;
            int bytesTransferred = 0;
            // Calculate bytesToTransfer
            foreach (var transaction in transactions)
                bytesToTransfer += transaction.Buffer.Length;
            // Execute the transactions in a thread save manner
            lock (I2CBusLock)
                bytesTransferred = @ this.Execute(transactions, timeout);
            // Validate successful completion of transaction
            if (bytesToTransfer != bytesTransferred)
                throw new I2CException(
                    "Error:  " +
                    "I2C transaction of " + bytesToTransfer.ToString() +
                    " byte(s) transferred " + bytesTransferred.ToString() +
                    " byte(s).");
        #endregion
    /// <summary>
    /// Class for extension methods
    /// </summary>
    public static class BME280Ext
        #region Reverse extension method of byte[] (PUBLIC)
        /// <summary>
        /// <para>Extension method Reverse of byte[] reverses and returns the bytes in the targeted array.</para>
        /// </summary>
        /// <param name="this">blind this parameter</param>
        /// <returns>
        /// </returns>
        public static byte[] Reverse(this byte[] @ this)
            var buffer = new Stack();
            foreach (var byteVal in @ this )
                buffer.Push(byteVal);
            var revBuffer = buffer.ToArray();
            for (int i = 0; i < @ this.Length; i++)
                @ this[i] = (byte)revBuffer[i];
            return @ this;
        #endregion
        #region ExtractUShort extension method of byte[] (PUBLIC)
        /// <summary>
        /// <para>Extension method ExtractUShort of byte[] returns a ushort value represented by </para>
        /// <para>the two bytes starting at the designated offset in the target byte array.</para>
        /// </summary>
        /// <param name="index">The designated start index to parse in the array</param>
        /// <returns>
        /// </returns>
        public static ushort ExtractUShort(this byte[] @ this, ref int index)
            if (index < 0 || index > @ this.Length - sizeof(ushort))
                    "Index value out of range in method " +
                    "byte[].ExtractUShort().");
            ushort value = (ushort)(@ this[index+1] << 8);
            value += (ushort)@ this[index];
            index += sizeof(ushort);
            return value;
        #endregion
        #region ExtractShort extension method of byte[] (PUBLIC)
        /// <summary>
        /// <para>Extension method ExtractShort of byte[] returns a short value represented by </para>
        /// </summary>
        /// <returns>
        /// </returns>
        public static short ExtractShort(this byte[] @ this, ref int index)
            if (index < 0 || index > @ this.Length - sizeof(short))
                    "byte[].ExtractShort().");
            ushort value = (ushort)(@ this[index + 1] << 8);
            return (short)value;
        #endregion
        #region ExtractIntFromBigEndianBuffer extension method of byte[] (PUBLIC)
        /// <summary>
        /// <para>Extension method ExtractIntFromBigEndianBuffer of byte[] returns an int value</para>
        /// <para>parsed from a buffer in big endian format. The number of bytes to parse at the</para>
        /// <para>index configurable, as is the option to shift the result, and by how many bits.</para>
        /// </summary>
        /// <param name="index">The index to start parsing</param>
        /// <param name="validByteCount">The count of bytes to parse</param>
        /// <param name="shiftRightBits">The number of bits to right shift the result</param>
        /// <returns>
        /// </returns>
        public static int ExtractIntFromBigEndianBuffer(this byte[] @ this, ref int index, int validByteCount, int shiftRightBits )
            // Validate index parameter
            if (index < 0 || index > @ this.Length - validByteCount)
                    "Variable 'index' value out of range in " +
                    "method byte[].ExtractIntFromBigEndianBuffer().");
            // Validate validByteCount parameter
            if (validByteCount < 1 || validByteCount > sizeof(int))
                    "Variable 'validByteCount' value out of range in " +
                    "method ExtractIntFromBigEndian().");
            // Validate shiftRightBits parameter
            if (shiftRightBits > 32)
                    "Varialbe 'shiftRightBits' value out of range in " +
            // Build the array to parse
            var buffer = new byte[] { 0, 0, 0, 0 };
            // Adjust the destination index basedd in the validByteCount
            var destinationIndex = sizeof(int)-validByteCount;
            // destinationIndex   validByteCount
            //       3                1
            //       2                2
            //       1                3
            //       0                4
            // Copy data into the buffer in the correct byte location
            for (var i = 0; i < validByteCount; i++) buffer[destinationIndex++] = @ this[index++];
            // Convert to little endian
            buffer = buffer.Reverse();
            // Convert to uint
            UInt32 temp = 0;
            temp = (temp | buffer[3]) << 8;
            temp = (temp |= buffer[2]) << 8;
            temp = (temp |= buffer[1]) << 8;
            temp = (temp |= buffer[1]);
            int result = (int)temp;
            // Shift if necessary
            if (shiftRightBits > 0)
                result = result >> shiftRightBits;
            return result;
        #endregion
@ srogers. Try running this code and tell me what you get.
using Cobra3AWS;
namespace BMETestApp
        private static BME280Device _device;
        private static double _pressureMb;
        private static double _tempC;
        private static double _relativeHumidity;
        private static double _tempF;
        private static double _pressureIn;
            _device = new BME280Device(0x76, 400) {AltitudeInFeet = 465.9F};
                _device.ReportTemperatureInCentigrade = false;
                _device.ReportPressureInMillibars = true;
                _device.Measure(out _tempC, out _pressureMb, out _relativeHumidity);
                Debug.Print("TempC=" + _tempC.ToString("F1") + " Pressure (in millibars)=" + _pressureMb.ToString("F2") + " Relative Humidity=" + _relativeHumidity.ToString("F2"));
                _device.ReportPressureInMillibars = false;
                _device.Measure(out _tempF, out _pressureIn, out _relativeHumidity);
                Debug.Print("TempF=" + _tempF.ToString("F1") + " Pressure (inches Hg)=" + _pressureIn.ToString("F2") + " Relative Humidity=" + _relativeHumidity.ToString("F2"));
                Thread.Sleep(2000);
@ scardinale -
[ol]I ran your test code with version 2 of the driver I posted earlier in this thread.
I noted that you changed my driver’s default frequency of 100kHz to 400kHz. My current I2C bus lines are short, so I did not experience any high-speed bus issues.
I changed the device address in the test code to 0x77 because that is the address of the BME280 chip I have mounted on my prototyping board.
I modified the test code you sent at line 22 to read:
so the debug output would be correct. You test code was causing the debug output to report degrees F when it indicated degrees C.[/ol
Here is the debug display in the output window:
TempC=20.3 Pressure (in millibars)=1032.58 Relative Humidity=42.50
TempF=68.5 Pressure (inches Hg)=30.49 Relative Humidity=42.50
TempC=20.3 Pressure (in millibars)=1032.67 Relative Humidity=42.50
TempC=20.3 Pressure (in millibars)=1032.66 Relative Humidity=42.50
TempC=20.3 Pressure (in millibars)=1032.57 Relative Humidity=42.50
TempC=20.3 Pressure (in millibars)=1032.59 Relative Humidity=42.50
TempC=20.3 Pressure (in millibars)=1032.63 Relative Humidity=42.50
TempC=20.3 Pressure (in millibars)=1032.60 Relative Humidity=42.50
TempC=20.3 Pressure (in millibars)=1032.54 Relative Humidity=42.50
TempC=20.3 Pressure (in millibars)=1032.62 Relative Humidity=42.50
TempC=20.3 Pressure (in millibars)=1032.61 Relative Humidity=42.50
TempC=20.3 Pressure (in millibars)=1032.55 Relative Humidity=42.50
TempC=20.3 Pressure (in millibars)=1032.65 Relative Humidity=42.50
TempF=68.7 Pressure (inches Hg)=30.49 Relative Humidity=42.50
// Here I put my finger on the BME280 chip to raise its temperature
TempC=22.9 Pressure (in millibars)=1032.54 Relative Humidity=45.60
TempF=73.5 Pressure (inches Hg)=30.49 Relative Humidity=45.70
TempC=24.8 Pressure (in millibars)=1032.53 Relative Humidity=48.70
TempF=76.8 Pressure (inches Hg)=30.49 Relative Humidity=48.70
// Note the minor change in pressure here. It could possibly be heat induced
// or just caused by reading noise. The data sheet indicates pressure readings
// are accurate only to 1 millibar. The difference seen here is 0.04 millibars.
TempC=25.7 Pressure (in millibars)=1032.49 Relative Humidity=48.80
TempF=78.2 Pressure (inches Hg)=30.48 Relative Humidity=48.80
TempC=26.3 Pressure (in millibars)=1032.44 Relative Humidity=50.30
TempF=79.3 Pressure (inches Hg)=30.48 Relative Humidity=50.30
TempC=26.8 Pressure (in millibars)=1032.50 Relative Humidity=51.80
TempF=80.2 Pressure (inches Hg)=30.48 Relative Humidity=51.80
TempC=27.1 Pressure (in millibars)=1032.50 Relative Humidity=51.90
TempF=80.9 Pressure (inches Hg)=30.48 Relative Humidity=51.90
TempC=27.4 Pressure (in millibars)=1032.48 Relative Humidity=51.90
TempF=81.5 Pressure (inches Hg)=30.49 Relative Humidity=51.90
TempC=27.7 Pressure (in millibars)=1032.47 Relative Humidity=53.40
TempF=81.8 Pressure (inches Hg)=30.48 Relative Humidity=53.40
TempC=27.9 Pressure (in millibars)=1032.44 Relative Humidity=53.40
TempF=82.2 Pressure (inches Hg)=30.48 Relative Humidity=53.40
TempC=28.1 Pressure (in millibars)=1032.48 Relative Humidity=53.40
TempF=82.5 Pressure (inches Hg)=30.48 Relative Humidity=53.40
TempC=28.2 Pressure (in millibars)=1032.39 Relative Humidity=54.90
TempF=82.7 Pressure (inches Hg)=30.48 Relative Humidity=54.90
TempC=28.3 Pressure (in millibars)=1032.48 Relative Humidity=54.90
TempF=82.9 Pressure (inches Hg)=30.48 Relative Humidity=54.90
TempC=28.4 Pressure (in millibars)=1032.43 Relative Humidity=54.90
TempF=83.1 Pressure (inches Hg)=30.48 Relative Humidity=54.90
// Here I removed my finger from the BME280 chip to let it cool
TempC=27.0 Pressure (in millibars)=1032.47 Relative Humidity=41.70
TempF=80.4 Pressure (inches Hg)=30.48 Relative Humidity=41.70
TempC=26.3 Pressure (in millibars)=1032.45 Relative Humidity=37.30
TempF=79.1 Pressure (inches Hg)=30.48 Relative Humidity=37.30
TempC=25.7 Pressure (in millibars)=1032.45 Relative Humidity=37.20
TempF=78.2 Pressure (inches Hg)=30.48 Relative Humidity=37.20
TempC=25.3 Pressure (in millibars)=1032.39 Relative Humidity=37.20
TempF=77.3 Pressure (inches Hg)=30.48 Relative Humidity=37.20
TempC=24.9 Pressure (in millibars)=1032.46 Relative Humidity=37.20
TempF=76.6 Pressure (inches Hg)=30.48 Relative Humidity=37.20
TempC=24.5 Pressure (in millibars)=1032.52 Relative Humidity=37.10
TempF=76.1 Pressure (inches Hg)=30.48 Relative Humidity=37.10
TempC=24.2 Pressure (in millibars)=1032.48 Relative Humidity=37.10
TempF=75.5 Pressure (inches Hg)=30.48 Relative Humidity=37.10
TempC=23.9 Pressure (in millibars)=1032.50 Relative Humidity=37.10
TempF=75.0 Pressure (inches Hg)=30.49 Relative Humidity=37.10
TempC=23.7 Pressure (in millibars)=1032.53 Relative Humidity=37.10
TempF=74.6 Pressure (inches Hg)=30.48 Relative Humidity=37.10
TempC=23.5 Pressure (in millibars)=1032.53 Relative Humidity=37.00
TempF=74.3 Pressure (inches Hg)=30.49 Relative Humidity=37.00
TempC=23.3 Pressure (in millibars)=1032.52 Relative Humidity=37.00
TempF=73.9 Pressure (inches Hg)=30.49 Relative Humidity=37.00
TempC=23.1 Pressure (in millibars)=1032.54 Relative Humidity=37.00
TempF=73.5 Pressure (inches Hg)=30.48 Relative Humidity=37.00
// Here I stopped the test.
Does this debug output give you any insight into the problems that you are seeing with my BME280Device driver?
I tried to locate the C# driver for the Mikroelectronica Weather Click board, but I could could not find it. Could you send me the code you are using with the Weather Click so that I can examine what they are doing with the driver code?
I don’t know if you tried version 2 of the driver I posted above. Did you, and if so, did it produce correct results?
Another question: Are you running the other Mikroelectronica code concurrently whilst testing my BME280Device driver? If so, this could explain a lot. The BME280 chip would be a shared resource in this case. Special coding would need to be done to insure that one driver did not mess up the expected state of the BME280 for other driver’s view of the BME280 chip.
I was mindful of the possibility of thread contention for sending commands and receiving data from more than one BME280 chip on the I2C bus. I made an extension method for I2CDevice to add a Transact method that does a thread safe execution of the Execute command. The Transact method insures that one thread’s use of the I2C (for the BME280Device driver) bus does not walk over another thread’s use of the I2C bus. The extension method does not, however, protect against different threads or different drivers trying to set different settings on the BME280 device. I attempted to improve this situation in Version 2 of the driver by resetting the BME280 device before each measurement.
In any case, to prevent concurrent use of the I2C bus when using I2CDevice, all threads using the bus would need to use the Transact extension method in place of the Execute method. Perhaps I need to stress that fact in the documentation of my driver.
Just some things to think about regarding how to resolve the issues you are experiencing with my driver.
Just to make sure that there was no contention between the Mikrobus.Net Quail board and drivers, I re-created the solution using a Secret Labs Netduino 3 Wifi. That way we eliminate any device incompatibilities with your driver and the MikroBus Board.
While still using the MikroE Weather click as my test device, I get the following output.
[line]TempC=22.8 Pressure (in millibars)=601.25 Relative Humidity=67.30
TempF=73.0 Pressure (inches Hg)=17.75 Relative Humidity=67.30
TempF=73.0 Pressure (inches Hg)=17.75 Relative Humidity=67.30[line]
The driver is your latest code that you posted and I changed the I2C Clock speed back to 100. Here is the code that I am using to produce the output.
using Cobra3AWS;
            _device = new BME280Device(0x76, 100) {AltitudeInFeet = 465.9F};
                _device.ReportTemperatureInCentigrade = true;
                Thread.Sleep(2000);
I kept the I2C address at 0x77 as this is this is the default for the Weather Click.
As a point of reference, MikroE does not supply C#/NetMF drivers for their click boards. All of the drivers to date have been writer by the Mikrobus.Net Team.
I have ordered a Adafruit BME283 breakout board to develop the SPI version of the MBN driver. Once I receive that board, I will test again to eliminate any physical differences between the Weather click and the Adafruit board.
I’ll let you know my findings.
I was going to upload the MBN Weather click driver to Codeshare but that would be inappropriate for this forum.
@ scardinale -
The only way that I can get pressure readings like the ones you see with my hardware and software is to stop the process in the debugger and change the value of property RawPressureADC to 0x80000. A value of 0x80000 is the value returned from the pressure reading registers when they are in the reset state, or presumably when the driver has programmed the chip not to do a reading for barometric pressure. The reasons I can think of for kind of a failure are:
[ol]The barometric pressure readings are not ready or have not been sent to the pressure reading registers when the block of registers holding all the returned data is read by the driver.
The chip as been programmed to skip the barometric pressure readings (which is possible), but not when my code resets and reprograms the chip for a single reading of all values.
The chip’s barometer section is broken.[/ol]
Reason 1 would indicate that the code in my driver is not correctly detecting the status register of the BME280. This is possible and the reason why I tried to detect the status first going busy, and then going idle. This caused your device to hang in the loop.
Reason 2 is not possible now that I have reset and reprogrammed the BME280 to do a Forced read of all three values with no oversampling.
Reason 3 is not possible if you are sure that your code has correctly read the BME280’s barometer and tracked local sources.
I would like to obtain a Microelektronica Weather click for testing with my code with, but I don’t want to buy one and pay for the shipping, and then never use it again. If you want, and could possibly do so, could you loan me by mail a Weather click to try on my system? I would only keep if for a couple of days, and return it promptly to you, hopefully with the problem resolved.
I know that I will need to drop the 5V connection and use a 3.3V connection to the Weather click’s power pin.
If you are agreeable, I can email you my address particulars.
@ srogers. I sent you a PM a few days ago. Please check your In Box.
Reason 3. My code has nothing at all to do with the results that I am seeing as I am only using your exact driver code. There is nothing else loaded and there is nothing to influence the result. The only thing that has changed is the initialization in the Sub Main which I already showed you.
@ scardinale, @ srogers:
Was this issue ever resolved? I would like to try the driver, but wanted to check first.
Thanks,
Rockybooth
@ Rockybooth. Try Steve’s driver and let us know if it is working for you.
