LED Matrix Module - Simple Alphabet Library
The LED Matrix Gadgeteer Module provides an 8x8 matrix of red LEDs for display. At the time of this writing, the module driver is in beta, and only supports a single API, DrawBitmap. The DrawBitmap method takes as an argument a byte array representing the on/off pattern for the LEDs. The structure of this byte array is discussed and illustrated on the Wiki here:
Since this API is relatively low-level, I decided to make life a little easier on myself by creating a relatively simple higher-level API, which currently includes uppercase English letters A-Z, Space, and numbers 0-9. The class, named Alphabet, exposes a static property for each letter/number, making it more intuitive to quickly display letters and numbers on the LED Matrix module.
To generate the glyphs, I created a quick and dirty visual editor in HTML and JavaScript, which you can try out here:
With each letter, I used my editor to generate the glyph, then copied the generated string into the āgetā accessor for the relevant property.
This has been tested on .NET MF / Gadgeteer 4.2 with the GHI 4.2 SDK beta, which is required for the LED Matrix module at the time of this writing.
