Snippet - HD4478 Module controled by Joystick
using GT = Gadgeteer;
namespace LCD
    public partial class Program
        const byte Ball = 0x6F;
        const uint DispRows = 4;
        const uint DispColoumns = 20;
        const int Speed = 250; //breaks in ms
        private int CursorPosX = 0;
        private int CursorPosY = 0;
        static Joystick.Position JoyPosition;
            Lcd.Clear();
            Lcd.SetCursor((byte) CursorPosY, (byte) CursorPosX);
            Lcd.Putc(Ball);
            GT.Timer timer = new GT.Timer(Speed);
            timer.Start();
            // Change direction @ <0.1 | >0.8
            JoyPosition = joystick.GetJoystickPosition();
            Debug.Print("JoyPositionX: " + JoyPosition.X.ToString());
            Debug.Print("JoyPositionY: " + JoyPosition.Y.ToString());
            Debug.Print("CursorPos: " + CursorPosX + " / " + CursorPosY);
            Debug.Print("--------");
            // X-Left
            if (JoyPosition.X < 0.1 && CursorPosX > 0)
                CursorPosX -= 1;
                LcdRedraw();
            // X-Right
            if (JoyPosition.X > 0.8 && CursorPosX < DispColoumns-1)
                CursorPosX += 1;
                LcdRedraw();
            // Y-Up
            if (JoyPosition.Y > 0.8 && CursorPosY > 0)
                CursorPosY -= 1;
                LcdRedraw();
            // Y-Down
            if (JoyPosition.Y < 0.1 && CursorPosY < DispRows - 1)
                CursorPosY += 1;
                LcdRedraw();
        private void LcdRedraw()
            Lcd.Clear();
            Lcd.Putc(Ball);
Using code tags will make your post more readable. This can be done in two ways:[ol]
Click the “101010” icon and paste your code between the
 tags or...
Select the code within your post and click the "101010" icon.[/ol]
(Generated by QuickReply)
