I just posted FEZ Cerberus and N18 Display Library on Codeshare. Feel free to discuss and make suggestions here.
How can I change this lines to MF4.3?
if (Util.SetSpecialDisplayConfig(this.config, Util.BPP_Type.BPP16_BGR_BE, (int)value, this.rs.Id))
this.currentOrientation = value;
throw new ArgumentException();
Thank you.
@ candelo - https://www.ghielectronics.com/docs/34/graphics#3271 should help you.
Thank you, but if I use only:
OutputPort RESET_PIN;
OutputPort BACKLIGTH_PIN;
RESET_PIN = new OutputPort(GHI.Pins.Generic.GetPin('A', 8), false);
BACKLIGTH_PIN = new OutputPort(GHI.Pins.Generic.GetPin('A', 13), true);
Display.Type = Display.DisplayType.Spi;
Display.Width = 160;
Display.Height = 128;
Display.SpiConfiguration = new SPI.Configuration(GHI.Pins.Generic.GetPin('A', 4), true, 0, 0, true, true, 8000, SPI.SPI_module.SPI1);
Display.ControlPin = GHI.Pins.Generic.GetPin('C', 3);
Display.Bpp = Bitmaps.BitsPerPixel.BPP16_BGR_BE;
Display.Save();
//Thread.Sleep(50);
var lcd = new Bitmap((int)Display.Width, (int)Display.Height);
lcd.DrawEllipse(GT.Color.Blue, 10, 10, 10, 10);
lcd.Flush();
my N18 only turn on the backlight.
What I need to do?
Thank you.
given your other post about Cerb40, this is the best code to use as the Cerb40 isn’t a true Gadgeteer board. I’d check your wiring since that’s the likely problem you have.
