Drawing a 3D cube
An accelerometer is connected to the Analog inputs of Embedded Master Development System. They are read using EM library to check the orientation. Then these values are used to rotate a 3D cube on the screen. Uses .Net Micro Framework 3.0
An old project but good to see how to draw a 3D cube
