I just posted Cerb-Family Hardware Watchdog on Codeshare. Feel free to discuss and make suggestions here.
nice
what is need to allow intervalSeconds as variable?
Great Question. It’s actually probably easy… The register WDG_RLR stores the countdown start value. Dividing it by half (0x7FF) would probably give you about 16 seconds. So the original code is this:
IWDG_RLR.SetBits(0xFFF); // Set starting number for countdown in watchdog 0xFFF is about 32 seconds
My guess is that changing to something like this would work:
IWDG_RLR.SetBits(0xFFF * (Math.Min(intervalSeconds, 32) / 32)); // Set starting number for countdown based on intervalSeconds
Thank you for posting your implementation of the watchdog.
I have 7 Cerbuino Bees deployed as environmental monitors at work. I use the webserver to serve up html when our system hits them. They have not been entirely reliable and need to be reset periodically. I have been using PowerState.RebootDevice(true) to force resets at regular intervals but in some cases this has not worked.
I will be testing code with your watchdog this week. Again, thank you.
I think you’re going to be a VERY happy camper. I have a web server running on a Cerb40 (and mIP of course) based device that is going on about 10 months of non-stop operation, likely thanks to this watchdog. I literally have not touched it in 10 months. This watchdog is the key to long term reliability and the LowLevel library from GHI is THE reason I moved to this platform. I also implemented my own RTC but GHI implemented that one and built it in shortly after I finished mine.
There are other great features that could be implemented with these classes and I encourage everyone to look at the STM32F4XX spec sheet! You can see from this example that it can be a fairly straightforward implementation…
Thanks Valkyrie-MT for all your contributions, you have been a huge help to this community…
so thank you
Thanks Valkyrie-MT, I have been testing this code on 7 cerbuinos the last 3 days and have not had a single problem. I really appreciate the help.
