Sm5100b-d PPP Help!
Has anyone gotten PPP to work on the sm5100b-d module?
I’ve called the Data switch command after setting up the APN and what not… but all i get is…
CONNECT
%~ÿ}#À!}!}#} }9}"}&} }} } }’}"}(}"}%}&(?â}?}#}%Â#}%-c~#$(@ @ )(#)^#U#@ #)#}} } }’}"}(}"}%}&(?â}?}#}%Â#}%-c~#$*(@ @ )(#)^#U
^#U}} } }’}"}(}"}%}&(?â}?}#}%Â#}%-c~#$(@ @ )(#)^_#_U$(%!@ @ @ (#$U%($)@ #$(!#)!$^)!#@ #)$~)~)$
NO CARRIER
and i’ve tried connecting it to PPP with PPP.Connect()… during, before, and after all of that response… and i still get connection failed. any suggestions?
Except for the fact that you get CONNECT and NO CARRIER, I would have sworn that that looks like the wrong baud rate… I didn’t look up the data sheet for teh cellular modem/shield to know whether the CONNECT and NO CARRIER is in your code or the response from the modem, but it might be worth checking the baud rate.
Can I see you whole C# project? As simplified as possible.
