Hello,
while I was playing with Glide on the Cobra, I’ve been suprised that a slider value that was changed in code (by a button press for example) did not fire the ValueChanged event :think:
The slider value is indeed changed and the display correctly updated (with a call to Invalidate(), of course), but no event is thrown.
I had to explicitely call the TriggerValueChangedEvent() method in order to have the event really fired.
I’ve tried the “same” code in a Windows WPF application and the event is fired as soon as the slider value is changed, no matter the way it’s changed : code or UI.
Is this normal behaviour for Glide or NetMF or did I miss something ?
Note that the event is fired correctly when I move the slider on the screen.
