Hey everyone, I’m getting all the tools ported to 4.3 and up on NuGet. I’ll post here as packages become available.
First off HAL 2.0.0
This package exposes interfaces that are helpful for creating drivers that can be used on any board as well as a few common classes.
[b]Interfaces:[/b] ICursorHAL, IDisplayHAL, IFileSystemHAL, IGameControllerHAL, IMainBoardHAL (for Gadgeteer), IModuleHAL (for Gadgeteer), INetworkHAL, IPowerHAL, IRealTimeClockHAL, IRegistry, IRegistryKey, ISoundHAL, IToneHAL, ITouchHAL, IUSBHAL
[b]Classes:[/b]
[b]Cursor[/b]
Defines both the image and hotspot for a cursor. Without a hotspot all "clicks" would take place at the top-left corner of a cursor. With a hotspot you can offset your render -Hotspot.X, -Hotspot.Y so that your hotspot is over the mouse location and you "click" with the right portion of your image.
[b]Driver[/b]
This is a wrapper to put around any of the above interfaces so they can be loaded directly into the AppDomain from a file system or resource. This is useful if you have an app that runs on multiple mainboards or with configurable hardware.
[b]DriverCollection[/b]
Collection of drivers for when you want to package more than one driver into a single file.
[b]LCDConfiguration[/b]
Exposed by IDisplayHAL so a mainboard can set its resolution to what the display requires. This is also helpful in the event of a full IFU where the display setting gets wiped, the driver will restore it.
[b]Socket[/b]
Used with Gadgeteer
[b]Tone[/b]
Used with piezo.
This package contains a few type classes that are helpful in almost any NETMF GUI Application. As always, all classes are AppDomain safe. All of these classes support .ToString()
[b]Point[/b]
A simple X/Y pair
[b]Rect[/b]
A rectangle. Supports methods to combine with another rectangle, check if a point is inside of the rectangle, check if the rectangle intersects another rectangle.
[b]Size[/b]
A simple Width/Height pair
Ah, the meat and potatoes of Skewworks in NETMF. There's a good bit here, so let's dive in.
[b]Display[/b]
This is the [b]primary[/b] class in the package. A singleton, automatically creates a bitmap the size of the detected screen. If you use Display.FlushScreen() (which is the [b]recommended[/b] way to flush), ScreenFlushing and ScreenFlushed events will be raised by Display.Instance. This is perfect for things like drawing overlays or mouse cursors.
[b]Colors & AccentColors[/b]
Two sets of statically available colors. Colors contains FromString and FromValue methods. In addition to RGB and HEX values to can supply [Accent],[Background],etc to have the current value from Themes.Current returned.
[b]Themes[/b]
Singleton class that allows you to keep a collection of themes, get and set the currently active theme.
[b]Theme[/b]
Class containing a collection of colors (Accent,Background,Chrome,etc) with a name.
[b]Images[/b]
Allows you to quickly create an image from bytes (including a PNG), the image type is automatically detected by the magic number. You can also create shadows and perform a "ColorConvert", this action changes every non-transparent pixel to the supplied color; useful for creating Windows 8 style apps.
[b]Fonts[/b]
A class with a collection of fonts for different sizes. Also contains static methods GetRect and GetSize.
This is the simplest way to use touch in NETMF.
[b]NativeTouch.StartCollection()[/b]
Starts touch collection and stores configuration inside of EWR. A small font is already included all calibration is done for you and there is a confirmation screen.
[b]NativeTouch.StartCollection(string filename)[/b]
Starts touch collection and stores configuration inside of a file on SD or USB. This is very useful when using touch across multiple applications, namespaces, or devices.
[b]Gestures are included.[/b]
Please note there were issues with GUI and NativeTouch packages. This was my first time creating NuGets with NETMF and there were some dependency errors. They have been corrected. If you are using these packages please update to the latest version.
Hi Tom,
where can one find some example on how to use the new packages?
i’m kind of interested in knowing how would one implement a way to load drivers on the fly (Example Sensors) where they would be compatible and allow the main interface to hook into their events and so one. make sense?
Edit: I got the error below as soon as I installed your package ( PM> Install-Package SKW-NETMF-HAL ) on a blank NETMF Mountaineer board project.
looks like TypeClasses is missing from the package!
For a video driver example, create a new class library project name T43. The first class will have code as follows:
using Skewworks.NETMF.HAL;
namespace T43
[Serializable]
public class T43Driver : Driver
private T43 _t43;
public override string Company
get
return "Skewworks, Inc.";
public override string Copyright
get
return "(c)2015 Skewworks, Inc.";
public override object DriverObject
get
if (_t43 == null)
_t43 = new T43();
return _t43;
public override DriverType DriverType
get
return DriverType.Display;
public override string Version
get
return "1.0.0.0";
Now add another class named T43 with the code below
namespace T43
[Serializable]
public class T43 : MarshalByRefObject, IDisplayHAL
#region Variables
private OutputPort _bkgLight;
#endregion
#region Constructors
public T43()
GHI.Processor.Display.Type = GHI.Processor.Display.DisplayType.Lcd;
GHI.Processor.Display.Width = 480;
GHI.Processor.Display.Height = 272;
// Only use if needed, see documentation.
//GHI.Processor.Display.PriorityEnable = false;
GHI.Processor.Display.OutputEnableIsFixed = false;
GHI.Processor.Display.OutputEnablePolarity = true;
GHI.Processor.Display.HorizontalSyncPolarity = false;
GHI.Processor.Display.VerticalSyncPolarity = false;
GHI.Processor.Display.PixelPolarity = false;
GHI.Processor.Display.HorizontalSyncPulseWidth = 41;
GHI.Processor.Display.HorizontalBackPorch = 2;
GHI.Processor.Display.HorizontalFrontPorch = 2;
GHI.Processor.Display.VerticalSyncPulseWidth = 10;
GHI.Processor.Display.VerticalBackPorch = 2;
GHI.Processor.Display.VerticalFrontPorch = 2;
GHI.Processor.Display.PixelClockRateKHz = 22166;
if (GHI.Processor.Display.Save())
Debug.Print("Display changed, resetting device");
Thread.Sleep(500);
PowerState.RebootDevice(true);
#endregion
#region Properties
public bool BacklightOn
get
if (_bkgLight == null)
return true;
return _bkgLight.Read();
set
if (_bkgLight != null)
_bkgLight.Write(value);
#endregion
To load the driver from the file system you can use these methods:
static Exception LoadDriver(string filename)
try
Assembly asm = Assembly.Load(File.ReadAllBytes(filename));
Type[] t = asm.GetTypes();
for (int i = 0; i < t.Length; i++)
if (t[i].BaseType != null && t[i].BaseType.FullName == "Skewworks.NETMF.HAL.Driver")
try
Driver d = (Driver)AppDomain.CurrentDomain.CreateInstanceAndUnwrap(asm.FullName, t[i].FullName);
LoadDriver(d.DriverType, d.DriverObject);
return null;
catch (Exception ex)
Debug.Print(ex.Message);
return ex;
else if (t[i].BaseType != null && t[i].BaseType.FullName == "Skewworks.NETMF.HAL.DriverCollection")
try
DriverCollection d = (DriverCollection)AppDomain.CurrentDomain.CreateInstanceAndUnwrap(asm.FullName, t[i].FullName);
for(int j =0; j < d.DriverTypes.Length; j++)
LoadDriver(d.DriverTypes[j], d.DriverObjects[j]);
return null;
return ex;
return new Exception("Interface not found");
return ex;
static void LoadDriver(DriverType type, object driver)
switch (type)
case DriverType.Cursor:
CursorDriver = (ICursorHAL)driver;
break;
case DriverType.Display:
DisplayDriver = (IDisplayHAL)driver;
if (Display.ScreenWidth == 0)
PowerState.RebootDevice(false);
break;
case DriverType.FileSystem:
FileSystemDriver = (IFileSystemHAL)driver;
break;
case DriverType.GameController:
GameController = (IGameControllerHAL)driver;
break;
case DriverType.Network:
NetworkDriver = (INetworkHAL)driver;
break;
case DriverType.Power:
PowerDriver = (IPowerHAL)driver;
break;
case DriverType.RealTimeClock:
TimeDriver = (IRealTimeClockHAL)driver;
break;
case DriverType.Registry:
Registry = (IRegistry)driver;
break;
case DriverType.Sound:
SoundDriver = (ISoundHAL)driver;
break;
case DriverType.Tone:
break;
case DriverType.Touch:
TouchDriver = (ITouchHAL)driver;
TouchDriver.StartCollection();
break;
case DriverType.USB:
USBDriver = (IUSBHAL)driver;
break;
This will contain all the nice-to-haves outside of GUI/HAL/etc. Currently has:
[b]StringSorter[/b]
I think the name pretty much speaks for itself
[b]Strings[/b]
AbsolutePath - Returns an absolute path from a base & relative path pair
FitToCount - Returns array of strings to fit within a certain character count per line, takes \r and \n into account.
FormatDiskSize - Takes a long and returns appropriate size X.XX[B/MB/GB/TB], precision int available.
InQuotes - Lets you know if a certain character position is inside of a quote set.
MonthFromString - Int from month string
MonthToShortString - Jan,Feb,etc from int
MonthToString - January,February, etc from int
NormalizeDirectory - Forces string to end with \
PadZeroLeft - Pads left side of string with X zeros to fit a certain count
PadZeroRight - Pads right side of string with X zeros to fit supplied length
ParseDate - Returns data from string (still needs some work)
RelativePath - Relative path from absolute and base pair
Replace - Replacement
ReplaceEmptyOrNull - Self explanatory
SplitComponents - Splits string by deliminator when NOT inside quotes
Tokenize - Returns tokenized array for string
WeekdayToShortString - Mon,Tue,Wed,etc from int
Skewworks.GUI 3.1.3
Added Border, ControlBottom, and ControlTop colors to Theme
Added .Instance to Themes
Made Fonts a singleton
Added new default theme
Made Type dependency non version specific
It's here! There will be updates but the first round of controls for all is ready. Let's dig in.
[b]Helpers[/b]
[em]Navigation Service[/em] - Singleton that takes care of navigation between pages (GoBack included!) with a simple NavigationService.Navigate. Please remember to call NavigationService.Initialize before trying to use it!
You can also do Drag & Drop. Navigation service takes care of all the GUI for you.
[em]SelectionDialog[/em] - Allows you to display a list of options for the user with the selected item (if any) returned to you.
[b]Controls[/b]
Button, CheckBox (the rendering for CheckBox & RadioButton is pretty sexy. It uses multiple Image32s and your Theme to render glorious anti-aliased items), ContextMenu, DropDownList, Image, ListBox, MenuItem, ProgressBar, ProgressRing, RadioButton, TextBlock, TextBox and VirtualKeyboard (100% customizable!!!)
[b]Containers[/b]
Grid, Page, Panel, and StackPanel
[b]Base Controls/Containers[/b]
Container, Control, ScrollableContainer
OK, stupid me just realized EXT and Controls were set to deploy to 4.2 even though they were 4.3. So if you’re using them just go under the updates tab and grab the latest (fixed) version.
Contains the basics for launching applications in new AppDomains
[b]Skewworks.NETMF.Applications.Manager 1.0.0[/b]
```cs]PM> Install-Package SKW-NETMF-ADM[/code
The AppManager performs the actuall launching of applications and persists all instances of Display,Themes,Fonts,Etc across the AppDomains.
[b]Skewworks.NETMF.GUI 3.1.6[/b]
Replaced Display.Instance with Display.Current to keep with conventions
Themes.Current now returns the Themes instance
Themes.Active added to return current Theme (previously Themes.Current)
[b]Skewworks.NETMF.EXT 1.0.3[/b]
Added Clipboard.Current
[b]Skewworks.NETMF.HAL 2.0.4[/b]
Added DeviceManager singleton to keep all loaded drivers between AppDomains, classes and programs
[b]Skewworks.NETMF.Controls 4.0.2[/b]
Updated to work with new Themes interface.
Application Manager
Removed domain restriction on .Current
Fixed marshalling issue
HAL
Added SocketCount to IMainboard
Added RequiredSockets to Driver
Removed domain restriction on DeviceManager.Current
GHIMainboards
Added Spider mainboard
Skewworks GUI
Removed domain restriction on Themes.Current
Removed domain restriction on Display.Current
Removed domain restriction on Fonts.Current
Placed all fonts under Fonts.Current
Skewworks EXT
Added Strings.VersionFromString
Added IO.CompareVersions
Added XMLReaderEX and XMLNodeEX
Nice work Skewworks. Any plan to add line graphs to your GUI library in the near future? I remember them being in Tinkr. Thanks for all of your contributions!
