I just got a couple of FEZ mini’s and they are awesome. And smaller than I expected, which is a good thing. What I wanted to suggest is… What I would have liked is a side by side size comparison of each board size relative to one another.
TC
TC
You mean a picture with all FEZes together side-by -side?
http://www.tinyclr.com/compare
Side - by - side. No pictures, but it will do the trick ;D
I like the idea of a side by side photo. Put a quarter next to each board for scale…
Yeah, I had no proper perspective of the sizes when I bought them. I know you could say… the measurements are available on-line; this is true. But a line of boards from pictured from several angles (the same) would be a welcome (and easy to do) view.
Just a thought
TC
Take a ruler, draw a rectangle on paper for each of the boards using the dimension from the comparison chart provided by GHI.
Take a scissor and cut out the rectangles.
Label each rectangle.
Place them side by side for comparison.
Not high tech enough?
I actually like the picture idea…why not it is just a picture and will make a customer happy
[quote]Take a ruler, draw a rectangle on paper for each of the boards using the dimension from the comparison chart provided by GHI.
Not high tech enough?[/quote]
This is what I did… but I think you know what I mean
[line]
Thanks Gus
Picture was taken and Josh is adding to website very shortly
Nice work it looks good.
Looks great and as always well designed!
It looks even better than I had hoped, makes the site even more professional
