If I call the read function on SignalCapture and there is no input at that time, the function hangs and never returns.
Is there a way to check if there is a signal before calling read()?
@ Dave McLaughlin - Open as input port. Go into a loop and keep reading the pin and counting changes. If there are “enough” changes then there is a signal?
There is ReadTimeout property you can get or set
