I have a UTC time from a GPS string that I want to use to set the RTC on the Domino.
But, I want to be able to read the time as my local time instead of the UTC. What is the best way to do this?
Our GPS driver already returns a DateTime object
http://www.tinyclr.com/downloads/Extension/Broch_GPSExtension.pdf
From there, you can set your system time like this
Microsoft.SPOT.Hardware.Utility.SetLocalTime(currDateTime);
Also, see this post
http://www.tinyclr.com/forum/2/104/
You can get item from anywhere, GPS, RTC, timeserver and then set the system clock
I am using Utility.SetLocalTime(), but how do I convert UTC to my local time for the offset between UTC and EST?
Hi Tony,
i just came across this statement that might help you out here?
How can I set the “correct” TimeZone?
Using the Microsoft.SPOT.ExtendedTimeZone.SetTimeZone(TimeZoneInfo) method.
(from .NET Micro Framework - FAQ)
hope it helps!
Thanks brett. We can always some some help from users like you;)
Brett,
The ExtendedTimeZone class is NOT in Microsoft.SPOT.
I am using .NET MF 4.0, is that something that was in a previous version?
I did a search on that class in the object browser and it turned up empty.
Any suggestions?
Timezone is supported through TimeService.SetTimeZoneOffset Method | Microsoft Learn
That is Microsoft.SPOT.Time.TimeService.SetTimeZoneOffset(-5*60);//-5 hours
