Newbie question that I can’t seem to figure out for some reason: Using a Fez Cerb40, I’m trying to cycle a pin between high output and low output to turn on a light.
static OutputPort RedLightPin = new OutputPort(GHI.Hardware.FEZCerb.Pin.PA13, false);
^^ current code that I’m trying, and then using
RedLightPin.Write(true/false);
to cycle it. Not getting a response though. Any ideas?
I probably worded that poorly. I have the light’s logic set up and powered so that when it sees the pin go to HIGH, it’ll turn the light on.
I just checked with a multimeter, and essentially when I tell the pin to go high, it shoots up for a fraction of a second and then drops back down to 0V. Is there a different line of code I should be using, or should I just try a bunch of different pins?
