I’m using the new version of the class of Chris:
* Servo NETMF Driver
* Coded by Chris Seto August 2010
* <chris@ chrisseto.com>
* Use this code for whatveer you want. Modify it, redistribute it, I don't care.
* I do ask that you please keep this header intact, however.
* If you modfy the driver, please include your contribution below:
* Chris Seto: Inital release (1.0)
* Chris Seto: Netduino port (1.0 -> Netduino branch)
* Chris Seto: bool pin state fix (1.1 -> Netduino branch)
using SecretLabs.NETMF.Hardware;
using SecretLabs.NETMF.Hardware.Netduino;
namespace Servo_API
public class Servo : IDisposable
/// <summary>
/// PWM handle
/// </summary>
private PWM servo;
/// <summary>
/// Timings range
/// </summary>
private int[] range = new int[2];
/// <summary>
/// Set servo inversion
/// </summary>
public bool inverted = false;
/// <summary>
/// Create the PWM Channel, set it low and configure timings
/// </summary>
/// <param name="pin"></param>
public Servo(Cpu.PWMChannel channelPin)
// Init the PWM pin
servo = new PWM((Cpu.PWMChannel)channelPin, 20000, 1500, PWM.ScaleFactor.Microseconds, false);
servo.DutyCycle = 0;
// Typical settings
range[0] = 1000;
range[1] = 2000;
public void Dispose()
disengage();
servo.Dispose();
/// <summary>
/// Allow the user to set cutom timings
/// </summary>
/// <param name="fullLeft"></param>
/// <param name="fullRight"></param>
public void setRange(int fullLeft, int fullRight)
range[1] = fullLeft;
range[0] = fullRight;
/// <summary>
/// Disengage the servo.
/// The servo motor will stop trying to maintain an angle
/// </summary>
public void disengage()
// See what the Netduino team say about this...
servo.DutyCycle = 0; //SetDutyCycle(0);
/// <summary>
/// Set the servo degree
/// </summary>
public double Degree
set
/// Range checks
if (value > 180)
value = 180;
if (value < 0)
value = 0;
// Are we inverted?
if (inverted)
value = 180 - value;
// Set the pulse
//servo.SetPulse(20000, (uint)map((long)value, 0, 180, range[0], range[1]));
servo.Duration = (uint)map((long)value, 0, 180, range[0], range[1]);
/// <summary>
/// Used internally to map a value of one scale to another
/// </summary>
/// <param name="x"></param>
/// <param name="in_min"></param>
/// <param name="in_max"></param>
/// <param name="out_min"></param>
/// <param name="out_max"></param>
/// <returns></returns>
private long map(long x, long in_min, long in_max, long out_min, long out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
Servo servo = new Servo(PWMChannels.PWM_PIN_D5);
servo.Degree = 30; // Change 'While' to 'For' to limit how many time it repeats
for (int j = 0; j < 3; j++)
for (int i = 0; i <= 180; i++)
servo.Degree = i;
Thread.Sleep(10);
for (int i = 180; i >= 0; i--)
servo.Degree = i;
Thread.Sleep(10);
I connecting servo in
3.3v
gnd
port 5 digital in Netduino
my servo is:
http://www.hobbyking…5g_0_14sec.html
not working! :-[
