Want to define Instance of “SerialPort” in Fez Mini (as show on the back page of Mini datasheet, as follows, has error message: (All other statements appear OK)
.netmf Code in VC# 2008:
using System.IO;
using System.Text;
using System.IO.Ports;
using GHIElectronics.NETMF.Hardware.LowLevel;
namespace SerialPortLoopBack
SerialPort UART = new SerialPort(“COM3”, 9600);
etc…
“System” is in the Project’ s References, which in MSDN .NET Framework Class Library states contains
Namespace: System.IO.Ports.SerialPort
Assembly: System (in System.dll).
using System.IO;
using System.Text;
using System.IO.Ports.SerialPort; //add this
SerialPort UART = new SerialPort("COM3", 9600);
