I’m trying to port develop a custom emulator device to be able to run my application there for demo purpose. I’m using .NET MF 4.3 to this.
This application uses UART for communication with external devices and this behaviour needs to be emulated in order to demo my application before sb decides to buy real hardware.
The problem I have is that from inside of my application I always receive ArgumentException from SerialPort::InternalOpen() method:
[quote]#### Exception System.ArgumentException - 0xfd000000 (1) ####
Message:
System.IO.Ports.SerialPort::InternalOpen [IP: 0000]
System.IO.Ports.SerialPort::Open [IP: 0018]
Gadgeteer.SocketInterfaces.NativeSerial::Open [IP: 0010]
Gadgeteer.Program::Run [IP: 0016]
A first chance exception of type ‘System.ArgumentException’ occurred in Microsoft.SPOT.Hardware.SerialPort.dll
[/quote]
This is my application PostInit method of my mainboard:
public override void PostInit()
var list = new ArrayList();
foreach (var socket in sockets)
if (socket.SerialPortName != null && socket.SerialPortName.Length > 0 && socket.SerialPortName == "COM1")
// Create and open serial port
var serial = SerialFactory.Create(
socket,
9600,
SerialParity.None,
SerialStopBits.One,
8,
HardwareFlowControl.NotRequired,
null);
serial.Open();
list.Add(serial);
serialPorts = new Serial[list.Count];
list.CopyTo(serialPorts, 0);
And this is how I declare “COM1” port in my custom emulator code:
public override void SetupComponent()
base.SetupComponent();
var serial = new SerialPortModule()
Baudrate = 9600,
ComPortHandle = new Microsoft.SPOT.Emulator.Com.ComPortHandle(Microsoft.SPOT.Emulator.Com.TransportType.Usart, 1),
Handshake = System.IO.Ports.Handshake.None,
PhysicalPortName = "COM10",
SupportNonStandardBaudRate = true
this.RegisterComponent(serial);
“COM10” is a virtual port registered on my laptop and it’s available from i.e. Hyper-Terminal so seems like emulator has this part defined properly.
Oh and SerialPortModule class:
public class SerialPortModule : ComPortToStream
private System.IO.Ports.SerialPort serialPort;
private string physicalPortName = "COM10";
private int baudrate = 9600;
private int readTimeout = 1000;
private Handshake handshake = Handshake.None;
protected override void InitializeProtected()
base.InitializeProtected();
if (this.Stream == null)
this.serialPort = new System.IO.Ports.SerialPort(this.physicalPortName, this.baudrate);
this.serialPort.ReadTimeout = this.readTimeout;
this.serialPort.Handshake = this.handshake;
this.serialPort.Open();
this.Stream = this.serialPort.BaseStream;
protected override void UninitializeProtected()
base.UninitializeProtected();
if (this.Stream != null)
this.serialPort.Close(); //also closes the underlying stream
this.serialPort = null;
this.Stream = null;
public string PhysicalPortName
get
return this.physicalPortName;
set
this.physicalPortName = value;
public int Baudrate
get
return this.baudrate;
set
this.baudrate = value;
public int ReadTimeout
get
return this.readTimeout;
set
this.readTimeout = value;
public Handshake Handshake
get
return this.handshake;
set
this.handshake = value;
Probably it is something obvious for someone who created custom emulator before but I’m new to this. I would be really grateful if you could help me to solve that out. The problem is that my application code doesn’t work on emulator only, and I do not have any problems on real FEZ hardware.
Best regards,
Lukasz
