Hello!
I am trying to serialize and deserialize a arraylist of objects. This object is called Pager and is defined as follows:
public class Pager
public int ID { get; set; }
public int RIC { get; set; }
public string Name { get; set; }
public string SerialNumber { get; set; }
In a different class, I have made an Arraylist containing these Pagers.
I want to be able to save this list of pagers to my SD card as a JSON file and then read it back again.
I have been able to serialize the arraylist correctly by doing this:
var result = JsonConverter.Serialize(Pagers.ToArray()).ToString();
Now, however when I try to deserialize by running below code:
var bson = JsonConverter.Deserialize(result).ToBson();
Pager[] pagers = (Pager[]) JsonConverter.FromBson(bson, typeof(Pager[]));
I get this error:
#### Exception System.NullReferenceException - CLR_E_NULL_REFERENCE (1) ####
#### Message:
#### GHIElectronics.TinyCLR.Data.Json.JsonConverter::PopulateObject [IP: 0013] ####
#### GHIElectronics.TinyCLR.Data.Json.JsonConverter::PopulateObject [IP: 036d] ####
#### GHIElectronics.TinyCLR.Data.Json.JsonConverter::FromBson [IP: 000d] ####
#### PagerServerV3._0.Files.PagerFile::AddPager [IP: 0032] ####
#### PagerServerV3._0.Program::Main [IP: 006a] ####
Exception thrown: 'System.NullReferenceException' in GHIElectronics.TinyCLR.Data.Json.dll
An unhandled exception of type 'System.NullReferenceException' occurred in
I don’t know of a different way of deserializing my data. What am I doing wrong?
Also, is it possible to use something else than an arraylist? E.g. a normal C# list for example.
I would really appreciate if someone could help me out here.
