I’m trying to serialize a class that I made to a byte array so that I can easily pass it over a network stream.
I am having an issue with the following exception when trying to serialize my object “System.NotImplementedException”.
It doesn’t provide anymore information about the exception.
[Serializable]
public class Payload
private const int maxByteArrayLength = 4;
private byte[] address = new byte[maxByteArrayLength];
private DeviceType deviceType;
private RequestFlag requestFlag;
private int messageValue;
private DateTime time;
private void SerializeMyObject(ref Payload ms, out byte[] data)
data = Reflection.Serialize(ms, typeof(Payload));
private void DeserializeMyObject(out Payload ms, ref byte[] data)
ms = (Payload)Reflection.Deserialize(data, typeof(Payload));
I would much appreciate any advice on how to serialize my object correctly.
EDIT: DeviceType & RequestFlag are both public enums.
Your right. Interesting. I didn’t realize that serialization is available on the bigger GHI devices. I always stuck to BitConverters and thought that’s the only way.
The code you supplied works brilliantly on my Spider. I can’t say the same for the Netduino Plus which I am also using, but I now understand why. Sorry I didn’t specify the hardware I was using.
Thanks Peter B;
The BitConverter you linked me to looks like it is what will fix my issue.
