Hopefully a simple question:
can the Serial-USB interface module (GHI-SER-USB-GM-287) be used as a serial debug / firmware load interface?
restrictions on which socket?
–Hugh
–Hugh
From the USB module description:
Yeah - debugging - but does that include the serial firmware and tinybooter updating?
I did not answer your firmware question because I don’t know the answer.
Normally, firmware is done via the client USB port. I would have to check the documentation for infield firmware update to see if that could be done via a serial port.
Ok - Thank you!
Yes all 100% will be on serial, from update to deploy…etc.
You have got to love FEZ Spider
Excellent! Thx for reply!
