Hello,
As my first netfm project I decided to write a Serial Port Server (which is something I could really use on UART level)…
Update: I was looking through the USB examples and have noticed that there are built in Events like device connected and device disconnected. Do they also exist for the network classes?
I started a new blog about my ChipWorkX experience at http://www.chipworkx.com (hope GHI won’t mind me using that domain name) I’ll update it as often as possible…
So my first part is implementing the telnetd (a TCP Server listing on Port 2001 for incoming connections). I noticed however that once I close the telnet session the while (true) function is “collecting” data as crazy… though I don’t know where they come from.
mySocket.Receive(received_data);
DataReceivedEvent(received_data);
I would actually need something like while (telnet client connected) because else once I disconnect I cannot connect again without resetting the device.
Below is my entire code so far…I know it’s not pretty but that will come once the functionality is done… It’s a private project so the code is public domain, feel free to copy it if you like it.
Thanks in advance for any help!
using System.Net;
using System.Net.Sockets;
using System.Text;
namespace SerialPortServer
public class NetListener
private Socket listenSocket;
private Thread NetReader;
public delegate void EventHandler(byte[] data);
public virtual event EventHandler DataReceivedEvent;
private Socket mySocket;
bool data_sent = false;
OutputPort LED1 = new OutputPort(ChipworkX.Pin.PC5, false);
public void run()
IPAddress hostIP = Network.systemIP;
listenSocket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
IPEndPoint ep = new IPEndPoint(hostIP, 2001);
try
listenSocket.Bind(ep);
listenSocket.Listen(1);
Debug.Print("listening...");
NetReader = new Thread(read_data);
NetReader.Start();
catch (Exception e)
Debug.Print(e.Message);
public void read_data()
if (listenSocket.Poll(100, SelectMode.SelectRead))
mySocket = listenSocket.Accept();
Debug.Print("Triggered a SelectRead " + mySocket.RemoteEndPoint.ToString());
byte[] received_data = new byte[1];
DataReceivedEvent += new EventHandler(DataReceived);
public void DataReceived(byte[] data)
try
LED1.Write(true);
Thread.Sleep(10);
if (!data_sent)
mySocket.Send(data, SocketFlags.None);
data_sent = true;
Debug.Print(Encoding.UTF8.GetChars(data)[0].ToString());
LED1.Write(false);
catch (Exception ex)
Debug.Print("Exception in DataReceived: " + ex.ToString());
finally
LED1.Write(false);
Network.init();
NetListener myListener = new NetListener();
myListener.run();
Debug.Print("I got to the end of main!");
