HI,
I have a problem with the Serial LCD.
I connected it on a Di5 FEZ Connect Shield and I test with the Official Driver but when I start the test, He write other charactere.
Some body have the same problem ?
Thank you !
Mickaël
HI,
Thank you !
Mickaël
Can you show your test code?
It’s the same to the exemple in Driver
// Create SerialLCD object assigned to the on Serial LCD connected to Di5
FEZ_Components.SerialLCD myLCD = new FEZ_Components.SerialLCD(FEZ_Pin.Digital.Di5);
// Print out
myLCD.Print("FEZ is here!");
Thread.Sleep(3000);
// Move the cursor to the second row and the forth column
myLCD.SetCursor(1, 3);
//Print our at the new position.
myLCD.Print("Hello World");
Thread.Sleep(3000);
// Move the cursor home
myLCD.CursorHome();
// Clear the screen
myLCD.ClearScreen();
for (int i = 0; i < 10; i++)// This loop prints out A,B,C,..etc in the same position on screen
// Print out a single character
myLCD.PutC((char)('A' + i));
Thread.Sleep(1000);
// Move the cursor left by one character.
myLCD.MoveLeft();
Thanks, and what do you actually get on the display?
In final, there are an “X” but before, they are many specials characters. (for exemple, a ‘X’ with a ‘-’ on the top)
Thank you for you help !
There are jumpers on the display that need to be set correctly as explained here http://www.ghielectronics.com/downloads/FEZ/Component/Broch_SLCD.pdf
It’s work now ! Thank you very much.
I start and and don’t read anywhere.
Micka
