Can anyone help me convert this code to work with the wire configuration as attached.
Its driving me crazy but i’m sure it easy to change
// Bansky.SPOT.LCD
// Bansky.SPOT.LCD provides API and helper function for LCD displays,
// to be used in .NET Micro Framework application. Goal of this library is
// to provide display output capabilites for headless Micro Framework CPUs.
// http://bansky.net/blog
// This code was written by Pavel Bansky. It is released under the terms of
// the Creative Commons "Attribution 3.0 Unported" license.
// http://creativecommons.org/licenses/by/3.0/
namespace zigbox.fezcobra2
/// <summary>
/// API for alfanumeric LCD display, controlled by HD44780 parallel interface in 4-bit mode.
/// </summary>
public class LCD4Bit
/// <summary>
/// Creates new intstance of HD44780 LCD display in 4-bit mode.
/// </summary>
/// <param name="provider">Data transfer provider.</param>
public LCD4Bit(ITransferProvider provider)
this.Provider = provider;
this.Encoding = System.Text.Encoding.UTF8;
this._backLight = false;
Init(true);
/// <summary>
/// Initializes display for communication.
/// Sets display to 1 line mode with 5x8 font.
/// </summary>
/// <param name="leftToRight">true if entry mode is from left to right.</param>
public void Init(bool leftToRight)
Thread.Sleep(100); // LCD controller needs some warm-up time
#region 4-bit initialization sequence
SendLcdCommand(0x48);
Thread.Sleep(64);
SendLcdCommand(0x03);
Thread.Sleep(50);
Thread.Sleep(50);
SendLcdCommand(0x02);
Thread.Sleep(50);
SendLcdCommand(0x2C); // Function set: 4-bit, 1 display line, 5x7 font
Thread.Sleep(20);
#endregion
// Set entry mode
SendLcdCommand((byte)(0x04 | ((leftToRight) ? 0x02 : 0x00)));
/// <summary>
/// Clears display and sets cursor position to zero.
/// </summary>
public void Clear()
SendLcdCommand(0x01);
/// <summary>
/// Sets the display properties
/// </summary>
/// <param name="visible">Is display on.</param>
/// <param name="backLight">Is backlight on.</param>
/// <param name="showCursor">Is cursor visible.</param>
/// <param name="blinkCursor">Is cursor blinking.</param>
public void Display(bool visible, bool backLight, bool showCursor, bool blinkCursor)
this._backLight = backLight;
int command = 0x08;
command |= (visible) ? 0x04 : 0x00;
command |= (showCursor) ? 0x02 : 0x00;
command |= (blinkCursor) ? 0x01 : 0x00;
SendLcdCommand((byte)command);
/// <summary>
/// Sets cursor position to zero and shifts display to original position.
/// </summary>
public void Home()
/// <summary>
/// Sets cursor position to given address.
/// </summary>
/// <param name="address">Display data RAM address.</param>
public void SetPosition(int address)
SendLcdCommand((byte)(address | 0x80));
/// <summary>
/// Moves cursor left or right.
/// </summary>
/// <param name="right">true to move cursor right.</param>
public void MoveCursor(bool right)
SendLcdCommand((byte)(0x10 | ((right) ? 0x04 : 0x00)));
/// <summary>
/// Shifts whole display area to left or right.
/// </summary>
/// <param name="right">true to shift right.</param>
public void ShiftDisplay(bool right)
SendLcdCommand((byte)(0x18 | ((right) ? 0x04 : 0x00)));
/// <summary>
/// Writes a specified number of bytes to the display using data from a buffer.
/// </summary>
/// <param name="buffer">The byte array that contains data to write to display.</param>
/// <param name="offset">The zero-based byte offset in the buffer parameter at which to begin copying bytes to display.</param>
/// <param name="count">The number of bytes to write.</param>
public void Write(byte[] buffer, int offset, int count)
int len = offset + count;
for (int i = offset; i < len; i++)
WriteByte(buffer[i]);
/// <summary>
/// Writes the specified string to display.
/// </summary>
/// <param name="text">String for output</param>
public void Write(string text)
byte[] buffer = this.Encoding.GetBytes(text);
Write(buffer, 0, buffer.Length);
/// <summary>
/// Sends one data byte to the display.
/// </summary>
/// <param name="data">The data byte to send.</param>
public void WriteByte(byte data)
int output = data;
output >>= 4; // set the first four data-bits
output |= (_backLight) ? 0x80 : 0; // set MSB to 1 when back light is On
output |= 0x40; // set R/S HIGH
output &= 0xDF; // set RW LOW
output &= 0xEF; // set Enable LOW
Provider.SendByte((byte)output);
output |= 0x10; // set Enable HIGH
Thread.Sleep(1);
data &= 0x0F; // set HByte to zero
data |= (byte)(output & 0xF0); // keep the control bits
Provider.SendByte(data);
data |= 0x10; // set Enable HIGH
data &= 0xEF; // set Enable LOW
/// <summary>
/// Sends HD44780 lcd interface command.
/// </summary>
/// <param name="data">The byte command to send.</param>
public void SendLcdCommand(byte data)
int output = data;
Thread.Sleep(1);
data &= 0x0F; // set four highest bits to zero
data |= (byte)(output & 0xF0); // keep the back light settings
/// <summary>
/// Writes data to specified address in character generator RAM.
/// This method is used to store custom graphic pattern into HD44780.
/// </summary>
/// <param name="address">Start offset in CGRAM.</param>
/// <param name="buffer">Data to write.</param>
public void WriteToCGRAM(byte address, byte[] buffer)
SendLcdCommand((byte)(0x40 | address));
int len = buffer.Length;
for (int i = 0; i < len; i++)
/// <summary>
/// Gets or sets hardware provider for data transfers to display.
/// </summary>
public ITransferProvider Provider;
/// <summary>
/// Gets or sets the byte encoding for conversion of text.
/// </summary>
public System.Text.Encoding Encoding;
private bool _backLight;
