“An unhandled exception of type ‘System.NullReferenceException’ occurred in GTM.GHIElectronics.SerCam.dll”
Error occurs when I call TakePicture on a serial camera. Also, anyone have a sample code for video capture using serCam?
@ TechDev - I think that exception occurs when serial data from the cam is either corrupt or not seen. You may want to look here for further information.
http://www.tinyclr.com/forum/topic?id=9085
I have 2 serial cameras. Both are exhibiting the same behavior (NullReferenceException) …
try registering for all the camera events
Please show stack-trace
I just tested here on spider and Hydra, and there is no problem.
Can you show us your code?
“…Also, anyone have a sample code for video capture using serCam?..”
And I hope this is what you want :))
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace TestSerCam4._2
public partial class Program
byte[] datajpg;
int index = 0;
timer.Tick +=<tab><tab>
timer.Start();
serCam.StartDataCaptured += new SerCam.StartDataCapturedEventHandler(serCam_StartDataCaptured);
serCam.OnDataCaptured += new SerCam.DataCapturedEventHandler(serCam_OnDataCaptured);
serCam.FinishDataCaptured += new SerCam.FinishDataCapturedEventHandler(serCam_FinishDataCaptured);
new Thread(VideoStreamming).Start();
void VideoStreamming()
if (!serCam.isBusy)
serCam.TakePicture();
else Thread.Sleep(50);
void serCam_FinishDataCaptured(SerCam sender)
display_T35.SimpleGraphics.DisplayImage(new Bitmap(datajpg, Bitmap.BitmapImageType.Jpeg), 0, 0);
void serCam_OnDataCaptured(SerCam sender, byte[] data)
if (index + data.Length > datajpg.Length)
throw new Exception("Error");
Array.Copy(data, 0, datajpg, index, data.Length);
index += data.Length;
void serCam_StartDataCaptured(SerCam sender, int sizeImage)
index = 0;
datajpg = new byte[sizeImage];
Could this be an internal attempt to fire an event when the user has not registered for it?
Started a new topic for my post… http://www.tinyclr.com/forum/topic?id=11161
@ Tomas - Hello Tomas and welcome to the community. Can you please start a new thread with your question? This thread is getting messy ot provide enough help.
Same for @ hoss please
