Hello DAT,
No change …
I tried 6 different cables (small, medium, long) same result "Exception System.Exception - CLR_E_FAIL (5) "
I followed your recomendation on SerCam42.cs (2nd way), but same result "Exception System.Exception - CLR_E_FAIL (5) ", see below :
using GT = Gadgeteer;
using GTI = Gadgeteer.Interfaces;
namespace Gadgeteer.Modules.GHIElectronics
// -- CHANGE FOR MICRO FRAMEWORK 4.2 --
// If you want to use Serial, SPI, or DaisyLink (which includes GTI.SoftwareI2C), you must do a few more steps
// since these have been moved to separate assemblies for NETMF 4.2 (to reduce the minimum memory footprint of Gadgeteer)
// 1) add a reference to the assembly (named Gadgeteer.[interfacename])
// 2) in GadgeteerHardware.xml, uncomment the lines under <Assemblies> so that end user apps using this module also add a reference.
/// <summary>
/// A SerCam module for Microsoft .NET Gadgeteer
/// </summary>
public class SerCam : GTM.Module
private GTI.Serial serialPort;
private const int DELAY_TIME = 200;
private static byte[] dataJPG;
public enum Camera_Resolution
SIZE_VGA = 0x00,
SIZE_QVGA = 0x11,
SIZE_QQVGA = 0x22,
// Note: A constructor summary is auto-generated by the doc builder.
/// <summary></summary>
/// <param name="socketNumber">The socket that this module is plugged in to.</param>
public SerCam(int socketNumber)
// This finds the Socket instance from the user-specified socket number.
// This will generate user-friendly error messages if the socket is invalid.
// If there is more than one socket on this module, then instead of "null" for the last parameter,
// put text that identifies the socket to the user (e.g. "S" if there is a socket type S)
Socket socket = Socket.GetSocket(socketNumber, true, this, null);
socket.EnsureTypeIsSupported('U', this);
serialPort = new GTI.Serial(socket, 115200, GTI.Serial.SerialParity.None, GTI.Serial.SerialStopBits.One, 8, GTI.Serial.HardwareFlowControl.NotRequired, this);
serialPort.ReadTimeout = 50000;
serialPort.WriteTimeout = 50000;
serialPort.Open();
ResetCamera();
// Baudrate
private static ushort BAUDRATE_9600 = 0xAEC8;
private static ushort BAUDRATE_19200 = 0x56E4;
private static ushort BAUDRATE_38400 = 0x2AF2;
private static ushort BAUDRATE_57600 = 0x1CC4;
private static ushort BAUDRATE_115200 = 0x0DA6;
private Thread thread;
#region Picture Capture
public void TakePicture()
if (thread == null)
thread = new Thread(ts);
thread.Start();
if (thread.ThreadState == ThreadState.Running)
Debug.Print("Cannot take picture at this time");
thread.Start();
private void ts()
ResetCamera();
StopFrameBufferControl();
int size = GetFrameBufferLength();
byte[] data = ReadFrameBuffer(size);
//GT.Picture pic = new Picture(data, Picture.PictureEncoding.JPEG);
OnPictureCapturedEvent(this, new Bitmap(data, Bitmap.BitmapImageType.Jpeg));
private bool StopFrameBufferControl()
CleanSerialPort();
byte[] send = new byte[] { 0x56, 0x00, 0x36, 0x01, 0x00 };
serialPort.Write(send, 0, send.Length);
Thread.Sleep(DELAY_TIME);
byte[] receive = ReadBytes();
if (receive != null && receive.Length >= 4)
if (receive[0] == 0x76 && receive[1] == 0 && receive[2] == 0x36 && receive[3] == 0 && receive[4] == 0)
return true;
return false;
private int GetFrameBufferLength()
CleanSerialPort();
byte[] send = new byte[] { 0x56, 0x00, 0x34, 0x01, 0x00 };
int size = 0;
if (receive != null && receive.Length >= 9)
if (receive[0] == 0x76 && receive[1] == 0 && receive[2] == 0x34 && receive[3] == 0 && receive[4] == 0x4)
size = receive[5] << 24 | receive[6] << 16 | receive[7] << 8 | receive[8];
return size;
private byte[] ReadFrameBuffer(int size)
CleanSerialPort();
byte[] size4byte = new byte[4];
byte[] header = new byte[10];
size4byte[0] = (byte)(size >> 24);
size4byte[1] = (byte)(size >> 16);
size4byte[2] = (byte)(size >> 8);
size4byte[3] = (byte)(size);
/////////dataJPG = new byte[size + 10]; =>>>>>>>>>>>>>>> Remove it to save memory and speed up
byte[] data = new byte[size];
byte[] send = new byte[] { 0x56, 0x00, 0x32, 0x0C, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, size4byte[0], size4byte[1], size4byte[2], size4byte[3], 0x0B, 0xB8 };
Thread.Sleep(30); /////////// Add 30 ms why? 0x0B,0xB8 ~ 3000 * 0.01 = 30
// Read header
ReadBytes(header, 0, 5);
// Read data
ReadBytes(data, 0, size);
// read header
ReadBytes(header, 5, 5);
return data;
public bool SetImageSize(Camera_Resolution resolution)
byte[] send = new byte[] { 0x56, 0x00, 0x31, 0x05, 0x04, 0x01, 0x00, 0x19, (byte)resolution };
if (receive != null && receive[0] == 0x76 && receive[1] == 0x00 && receive[2] == 0x31 && receive[3] == 0x00 && receive[4] == 0x00)
return true;
return false;
#endregion
#region Helper Functions
private string ResetCamera()
byte[] send = new byte[] { 0x56, 0x00, 0x26, 0x00 };
if (receive != null && receive.Length > 0)
return ConvertBytesToString(receive);
return "";
private string ConvertBytesToString(byte[] data)
string str = "";
for (int i = 0; i < data.Length; i++)
str += new string(new char[] { (char)(data[i]) });
return str;
private void CleanSerialPort()
serialPort.DiscardInBuffer();
serialPort.DiscardOutBuffer();
private byte[] ReadBytes()
byte[] data = null;
int byteread = serialPort.BytesToRead;
if (byteread > 0)
data = new byte[byteread];
ReadBytes(data, 0, data.Length);
return data;
private void ReadBytes(byte[] data, int offset, int count)
//serialPort.Read(data, offset, count);
int cnt = 0;
int bytetoread = 0;
int timeout = 0;
while (cnt < count)
bytetoread = serialPort.BytesToRead;
if (bytetoread == 0)
Thread.Sleep(1);
timeout++;
if (timeout > serialPort.ReadTimeout) break; // ReadTimeout
continue;
if (bytetoread > (count - cnt)) bytetoread = (count - cnt);
if (bytetoread > 0)
cnt += serialPort.Read(data, (offset + cnt), bytetoread);
int ReadBytes(byte[] buff, int offset)
if (byteread + offset > buff.Length) byteread = buff.Length - offset;
if (byteread > 0)
serialPort.Read(buff, offset, byteread);
return byteread;
#endregion
#region Events
/// <summary>
/// Represents the delegate that is used for the <see cref="PictureCaptured"/> event.
/// </summary>
/// <param name="sender">The <see cref="SerCam"/> object that raised the event.</param>
/// <param name="picture">A <see cref="T:Gadgeteer.Picture"/> containing the captured image.</param>
public delegate void PictureCapturedEventHandler(SerCam sender, Bitmap picture);
/// <summary>
/// Event raised when the <see cref="Camera"/> has completed an image capture.
/// </summary>
/// <remarks>
/// Handle the <see cref="PictureCaptured"/> event to process image data
/// after you call the <see cref="TakePicture"/> method. These methods
/// process the image data from the camera asynchronously,
/// and raise this event when the processing is complete.
/// </remarks>
public event PictureCapturedEventHandler PictureCaptured;
private PictureCapturedEventHandler OnPictureCaptured;
/// <summary>
/// Raises the <see cref="PictureCaptured"/> event.
/// </summary>
/// <param name="sender">The <see cref="SerCam"/> that raised the event.</param>
protected virtual void OnPictureCapturedEvent(SerCam sender, Bitmap picture)
if (OnPictureCaptured == null) OnPictureCaptured = new PictureCapturedEventHandler(OnPictureCapturedEvent);
if (Program.CheckAndInvoke(PictureCaptured, OnPictureCaptured, sender, picture))
PictureCaptured(sender, picture);
#endregion
Is there a way to check my camera ?
