Hello,
I’ve installed .net micro framework 4.3 . But, I can’t see
also instead of serCam.newImageReady, I have :
```cs]serCam.isNewImageReady[/code
which always return FALSE !!!!
all of them are stated in this topic:
https://www.ghielectronics.com/docs/176/serial-camera-module
What is the problem?
thanks
@ Ehsan Ansari - In a new Gadgeteer project, can you try this example: https://www.ghielectronics.com/docs/176/serial-camera-module ?
@ John -
No, I could not run that test in a new project. the problem is that the method of getImage is not even defined and accessible in my example…
@ andre.m -
On that thread discussions were not exactly close to my question. and it was a long time that the topic was not updated.
If it is opposite to your policy that a question asked more than one time, I apologize…
@ Ehsan Ansari - If that code does not run, something did not get installed properly. I would uninstall everything related to our SDK and reinstall following the steps on .NET Micro Framework – GHI Electronics
Thanks everybody!
problem is solved. it was just about update project properties to version 4.3…
