If anyone wants to try LoRa with NetMF (TinyCLR shortly) I ported my WIndows 10 IoT Core .Net library
Works with Arduino compatible shields from www.elecrow.com , www.dragino.com & www.makerfabs.com
I have the code running on Netduino, ingenuitymicro and just about to pull apart my electric longboard to get a Fez Panda III for testing.
Upload data to Azure IoT Hubs/Azure IoT Central and AdaFruit.IO from embedded devices.
@Kiwibryn
blog.devmobile.co.nz
I forgot to mention the Windows 10 IoT Core field gateways which make it easy to get data from devices to the cloud.
I’m working on hackster projects similar to my nRF24L01 field gateways
So currently only a couple of “work in progress” GitHub repos
There are also a number *duino and other device sample clients.
We need to convince @Justin to build some RFM69 & LoRa devices
New Zealand is 915MHz so some EU 868MHz or global 433MHz testing would be helpful.
I’m working on RFM69 library as well.
@Kiwibryn
Brett
October 11, 2018, 7:05am
5
um, you don’t know @justin that well then do you. I think those are in the bag already… and if not, pretty close.
Thanks for sharing, very valuable!!
May be that it doesn’t match your quality requirements but there is already a Rfm69 driver for NETMF. For me it works quite reliably.
https://old.ghielectronics.com/community/codeshare/entry/1096
Did you consider to use Azure Table Storage as a Cloud storage. It’s very cheap. I use it to store a set of Sensor Data every 10 minutes and it costs only about 2 Cents per month.
