I’m precalculating timing buffers for Signal Generator pins and executing them in non-blocking mode.
After all 3 buffers are precalculated, I create an instance of the “Controller” class and scheduling its “Run” method in the improvised “thread pool” that runs one thread at a time. When Run method executes, it execute 3 Signal Generators in non-blocking mode and waits until all 3 Signal Generators are finished using flowing code
while (XStepPort.Active || YStepPort.Active || ZStepPort.Active)
// block untill all SignalGenerators finished toggling
ISSUE:
It looks like that the SignalGenerator.Active does not work in Release mode, it returns false even if SignalGenerators still toggling. :wall:
Class code:
internal class Controller
public SignalGenerator XStepPort { get; set; }
public SignalGenerator YStepPort { get; set; }
public SignalGenerator ZStepPort { get; set; }
public OutputPort XDirPort { get; set; }
public OutputPort YDirPort { get; set; }
public OutputPort ZDirPort { get; set; }
public uint[] XTimingBuffer { get; set; }
public uint[] YTimingBuffer { get; set; }
public uint[] ZTimingBuffer { get; set; }
public bool XDirValue { get; set; }
public bool YDirValue { get; set; }
public bool ZDirValue { get; set; }
public int Dwell { get; set; }
public void Run()
// direction control
if (XDirPort.Read() != XDirValue)
XDirPort.Write(XDirValue);
if (YDirPort.Read() != YDirValue)
YDirPort.Write(YDirValue);
if (ZDirPort.Read() != ZDirValue)
ZDirPort.Write(ZDirValue);
// movement control
if (XTimingBuffer.Length > 0)
XStepPort.Set(true, ZTimingBuffer);
if (YTimingBuffer.Length > 0)
YStepPort.Set(true, YTimingBuffer);
if (ZTimingBuffer.Length > 0)
ZStepPort.Set(true, ZTimingBuffer);
// this seem to work only in Debug mode !
if (Dwell > 0)
Thread.Sleep(Dwell);
Do you have a USB cable connected but no Debugger SW connected to the Controller?
The NETMF runs in to serious timeouts when trying to send debug info out. This also happens when you build in relese mode.
At least up to NETMF 4.3 you Need to have VS MFDeploy or FezConfig connected to the Controller when a USB cable is connected.
I did have a USB connected. I’ll try to run disconnected.
But I don’t think the issue is related to it. As it works as expected in Debug mode with debugger attached. And don’t work as expected when application deployed and debugger is not attached. Works as expected means: It should not start new SignalGenerator thread until execution of the previous thread is complete as the following code should block the execution.
// do nothing
I’m using FEZ Cobra III
The complete example would be 40+ classes. I’ll have to create completely different project.
But try to remove “Debug.Print(“Blocking…” + cnt++);” from the while loop, I can’t do anything inside the loop as it takes too long, it is very important to me to return as soon as all 3 Signal Generators finish executing.
In my app is more like in the code below (not the exact code but close enough)
static class Program
ThreadUtil.MaximumThreads = 1;
for (int i = 0; i <= 5; i++)
Controller controller = new Controller
XStepPort = new SignalGenerator((Cpu.Pin)(0 * 32 + 27), false),
YStepPort = new SignalGenerator((Cpu.Pin)(0 * 32 + 28), false),
ZStepPort = new SignalGenerator((Cpu.Pin)(0 * 32 + 29), false),
XTimingBuffer = new uint[1000],
YTimingBuffer = new uint[1000],
ZTimingBuffer = new uint[1000]
ThreadUtil.Queue(controller.Execulte);
public void Execulte()
// movement control
if (Dwell > 0)
public static class ThreadUtil
/// <summary>
/// Synchronizes thread queue actions
/// </summary>
private static readonly object lockObject = new object();
/// <summary>
/// List storing our available threadpool threads
/// </summary>
private static readonly ArrayList availableThreads = new ArrayList();
/// <summary>
/// Queue of actions for our threadpool
/// </summary>
private static readonly Queue threadActions = new Queue();
/// <summary>
/// Wait handle for us to synchronize de-queuing thread actions
/// </summary>
private static readonly ManualResetEvent threadSynch = new ManualResetEvent(false);
/// <summary>
/// Maximum size of our thread pool
/// </summary>
public static int MaximumThreads { get; set; }
/// <summary>
/// Starts a new thread with an action
/// </summary>
/// <param name="start"></param>
public static void Start(ThreadStart start)
try
var t = new Thread(start);
t.Start();
catch (Exception ex)
Debug.Print(ex.ToString());
/// <summary>
/// Queues an action into the threadpool
/// </summary>
public static void Queue(ThreadStart start)
if (MaximumThreads == 0)
MaximumThreads = 1;
lock (lockObject)
threadActions.Enqueue(start);
// if we haven't spun all the threads up, create a new one
// and add it to our available threads
if (availableThreads.Count < MaximumThreads)
var t = new Thread(ActionConsumer);
availableThreads.Add(t);
t.Start();
// pulse all waiting threads
threadSynch.Set();
/// <summary>
/// Indefinitely wait until an action is queued. When an action is de-queued safely execute it
/// </summary>
private static void ActionConsumer()
// wait on action pulse
threadSynch.WaitOne();
ThreadStart action = null;
// try and de-queue an action
lock (lockObject)
if (threadActions.Count > 0)
action = threadActions.Dequeue() as ThreadStart;
// Safely reset the mutex so that everyone waits until the next action is queued
threadSynch.Reset();
// if we got an action execute it
if (action != null)
try
action();
Debug.Print("Error in thread pool: " + ex);
Stupid question, but what Visual Studio version are you using? I couldn’t get anything running reliable in VS2015, with VS2013 theres no problem. That begins with the debugger that can’t be attached and ends with the execution of my application just stops after some time or it doesn’t startup completly at all (on a G120 and a G400). When I use VS2013 there are no issues at all.
Did this ever get fixed? I installed GHI Electronics NETMF SDK 2016 R1 on a new PC and updated the firmware on a Cobra II to use it. If I am not actively debugging or I run a release version of the code, it executes VERY slowly. If I plug the Cobra II into a USB power supply (as opposed to a computer) it runs just fine (debug or release). Since this was working fine before (a year or so ago) with the old FW (don’t recall the exact version, but for sure this worked fine on NETMF v4.2) it seems like this is a FW issue, though it could also be a NETMF 4.3 issue.
I have a workaround (don’t do that :)) but it seems like this is a bug that should be addressed at some point. Are other people still seeing it? Do you need more information to figure out what is really wrong?
It’s not necessarily a bug in the firmware. When you attach the debugger, the context-switching behavior of your code changes, because the debugger support code in the interpreter is active. There will be more context switching or just different timing in your code due to debugger ‘noise’ and this can unblock deadlocks and improve perceived performance when what you really have is a bug in your threading or resource management (locks/mutexes) code.
If performance decreases when you detach the debugger, it can either be a known issue with Debug.Print (which should go away in Release builds) or a bug in your thread management (which will not go away in Release code).
It seems that even in Release mode Debug.GC() will attempt to send stuff using Debug.Print() so the issue can't be resolved with using Release code.
So, any idea if/when the well known issue with Debug.Print() will be fixed? I can work around the issue, by remembering it is there, but it would be nice to not have to do so. I use Debug.GC() to get an idea of how much memory is leaking (and fix it, if it is).
