It appears that all of Seeed’s code is still on 4.1. Using the Gadgeteer templates, I went ahead and ported (I use that term liberally) their Temperature and Humidity sensor code to 4.2. I’ve included a test project that seems to work. Inside the Release folder is an MSI file that will install the assemblies in their proper locations.
I don’t know who to talk to about getting code pushed back into the Gadgeteer codebase on Codeplex – Gus, could you get me access?
My lab is starting a massive wireless sensor network project that we’ll be prototyping using a lot of GHI modules, so I’m looking forward to being able to contribute code and PCB designs to the project!
I also use the temperature module of seeed and it requires Net MicroFramework 4.1. I actually have 4.2. Where or how can I update the driver?
The error is that the device is not found when I start my program.
