Seeed Cellular Radio Module sending SMS?!
Hello
I wanted to start a small project with a gsm module
would I have read through some posts but unfortunately I’m not a simple task I manage to send a sms
someone has an idea what I’m doing here wrong
1 step: cellularRadio.PowerOn(50);
2 step: sending pin
3 step: wait if the modul ist registered
4 step: send sms cellularRadio.SendSms(“4915019855555”, “test”);
   public partial class Program
            joystick.JoystickPressed += new Joystick.JoystickEventHandler(joystick_JoystickPressed);
            joystick.JoystickReleased += new Joystick.JoystickEventHandler(joystick_JoystickReleased);
            button.ButtonPressed += new Button.ButtonEventHandler(button_ButtonPressed);
            cellularRadio.DebugPrintEnabled = true;
            cellularRadio.PinStateRetrieved += new CellularRadio.PinStateRetrievedHandler(cellularRadio_PinStateRetrieved);
            cellularRadio.GsmNetworkRegistrationChanged += new CellularRadio.GsmNetworkRegistrationChangedHandler(cellularRadio_GsmNetworkRegistrationChanged);
        void cellularRadio_GsmNetworkRegistrationChanged(CellularRadio sender, CellularRadio.NetworkRegistrationState networkState)
            if(Enum.Equals(networkState, CellularRadio.NetworkRegistrationState.Registered))
            {                Debug.Print("NetworkRegistrationState -->" + networkState.ToString());            }
            Debug.Print("NetworkRegistrationState           ++>" + networkState.ToString());
        void cellularRadio_PinStateRetrieved(CellularRadio sender, CellularRadio.PINState pinState)
            if (Enum.Equals(pinState, CellularRadio.PINState.PIN ))
            {   Debug.Print("Module initialized, sending PIN...");
                cellularRadio.SendATCommand("AT+CPIN=9551");
        void button_ButtonPressed(Button sender, Button.ButtonState state)
            if (button.IsLedOn) button.TurnLEDOff();
            else button.TurnLEDOn();
            cellularRadio.SendSms("491501985555", "test");
        void joystick_JoystickReleased(Joystick sender, Joystick.JoystickState state)
            Debug.Print("joystick wurde los gelassen");            led7r.TurnLightOn(7);
The Output Monitor in Visual Studio says Error in the sending metode!!
Using mainboard GHIElectronics-FEZHydra version 1.2
Program Started
Der Thread '<Kein Name>' (0x3) hat mit Code 0 (0x0) geendet.
CellularRadio : Turning ON
CellularRadio : Turning module on
CellularRadio : <
RDY
CellularRadio : <
+CREG: 2
+CREG: 0
+CGREG: 0
+CFUN: 1
+CPIN: SIM PIN
CellularRadio : <AT+CPIN=9551
CellularRadio : SENT: AT+CPIN=9551
NetworkRegistrationState           ++>2
CellularRadio : <
OK
CellularRadio : <
+CREG: 2
CellularRadio : <AT
OK
CellularRadio : SENT: AT+CMGF=1
CellularRadio : <AT+CMGF=1
OK
CellularRadio : SENT: AT+CSDH=0
CellularRadio : <AT+CSDH=0
OK
CellularRadio : SENT: AT+CPBS="SM"
CellularRadio : <AT+CPBS="SM"
OK
CellularRadio : SENT: AT+CPMS="SM"
CellularRadio : <AT+CPMS="SM"
CellularRadio : SENT: AT+CNMI=2,1,0,1,0
CellularRadio : SENT: AT+COLP=1
CellularRadio : <
+CPMS: 0,20,0,20,0,20
OK
AT+CGREG=1
OK
CellularRadio : SENT: AT+CGREG=1
CellularRadio : <AT+CREG=1
OK
CellularRadio : SENT: AT+CREG=1
Der Thread '<Kein Name>' (0x6) hat mit Code 0 (0x0) geendet.
CellularRadio : <
Call Ready
CellularRadio : <
+CGREG: 2
CellularRadio : <
+CREG: 1
NetworkRegistrationState -->1
NetworkRegistrationState           ++>1
CellularRadio : <
+CGREG: 0
CellularRadio : <AT+CMGS="+491501985555"
CellularRadio : <test>
CellularRadio : <
ERROR
> test>
CellularRadio : <
ERROR
Das Programm "[13] Micro Framework application: Verwaltet" wurde mit Code 0 (0x0) beendet.
I forget somthing?!
Or i have the wrong driver
Many thanks for every tip!!
Hiya W3, welcome.
First up, edit your post and highlight the code section and hit the 1010101 button to mark it as code.
Almost all the cellular module issues I’ve seen are that it is a BEAST when it comes to drawing power. Probably best to tell us about how you’ve got your devices wired up as that’ll be a common question :slight_smile:
Hello Brett
sorry for my “ugly” post :wink:
thanks for the tip …
This small test runs on the Hydra Mainboard and is supplied by UsbClientDP and external power supply with 12V
and the CellularRadio is plugged in port 6.
 private void InitializeModules()
            // Initialize GTM.Modules and event handlers here.
            usbClientDP = new GTM.GHIElectronics.UsbClientDP(2);
            button = new GTM.GHIElectronics.Button(3);
            led7r = new GTM.GHIElectronics.LED7R(4);
            cellularRadio = new GTM.Seeed.CellularRadio(6);
            joystick = new GTM.GHIElectronics.Joystick(14);
No worries.
The issue is usually CURRENT not voltage, can you please tell us about your 12v supply’s max current ?
Hello Brett
my external power supply max current is 5A
I think it should be enough for this small thing :wink:
my power supply shows
IDLE Mode 12.0V at 0.10A - 0.13A
Sending Mode 12.0V at 0.15A
I must look at the send routine
cellularRadio.SendSms();
did you find your error
No The error is Not fixed
In this week i dont habe time for this :frowning:
HI,
now works the small send function
But I have not changed anything O_o
Could you solve it?
I’d be interested in being able to send a sms via .net gadgeteer
