Not sure is this answers your question, but I have come across two phenomena with the Seeed gyro module:
The X and Z axis are mixed-up.
At high levels of sensing (>10z) the numbers are all over the place.
The issues were concurred in this forum (who? don’t remember) and by other forums.
This is 4.1, mind you.
I wouldn’t mind if it was just a problem (like the LED) where outputs were mixed up but it’s the “numbers are all over the place” thing that I don’t get.
I was expecting after a calibrate (where device was flat on desk) that it would subsequently report XYZ degrees tilt as I move it around.
I’ve seen a couple of other articles here where they keep track of previous readings and where they multiply the figures by (14.375 * 60) but no real difference when I’ve tried those. I just get seeming random numbers back. Seen the video on YouTube (Seeed Gyro Graphics - YouTube) with the number and ellipses but it seems to be reporting the same random numbers mine does.
Do I have a broken module or am I missing something fundamental about how the gyro works. Does anyone actually have this working?
I have not tried that module but apart from the - reading it looks normal to me.
Gyros even at rest have quite a large drift and that’s one of the reasons imu’s use a mixture of gyros and accel’s to get a accurate reading.
What are you trying to achieve?
I am making a few assumptions here, if you multiply your reading by “(14.375 * 60)” i belive your answer will be mdp/ min, or milli degrees per minute. if you want degees per second then use
(reading * 0.014375f)
radians per second would be
(reading * 0.014375f * 0.01745329252f)
EDIT:
After looking at the Seeed software it appears that one of my assumptions is incorrect, to multiply we need to use the receipical 1/14.375 = 0.069565 so
(reading * 0.069565f)
(reading * 0.069565f * 0.01745329252f)
The code
(reading / 14.375f)
is already used in the gyro driver so you can see why your numbers appear large (a reading of 1 = 0.069565), but due to the calibration method you will see smaller numbers.
I must have misunderstood what the gyro was giving me, from what you say it returns a rate of change - I thought that was what the accelerometer returned.
In layman’s terms:
I want to mount a sensor on top of a remote controlled car and
tell the angle it's leaning to to the left or right, and to
tell the angle it's going up or down hill.
I assumed that would be a +/-X reading and a +/-Y reading and easy to get…
Yup gyros measure the rate of change, you might get away with a 3 axis accel on the car but an imu would be far better
Have a look at the arduimu v3 from diydrones that’s what I use and they are very good.
