Hey
Is there any example of how to use the SslStream for secure socket connections? my first attempts has all resulted in:
#### Exception System.InvalidOperationException - CLR_E_INVALID_OPERATION (1) ####
#### Message:
#### GHIElectronics.TinyCLR.Devices.Network.Provider.NetworkControllerApiWrapper::AuthenticateAsClient [IP: 0000] ####
#### System.Net.Security.SslStream::AuthenticateAsClient [IP: 0016] ####
#### System.Net.Security.SslStream::AuthenticateAsClient [IP: 0009] ####
#### System.Net.Security.SslStream::AuthenticateAsClient [IP: 0008] ####
#### Network.SocketTls::OpenSocketTLS [IP: 0051] ####
#### Cleverhouse.Program::Main [IP: 001a] ####
Exception thrown: âSystem.InvalidOperationExceptionâ in GHIElectronics.TinyCLR.Devices.Network.dll
An unhandled exception of type âSystem.InvalidOperationExceptionâ occurred in GHIElectronics.TinyCLR.Devices.Network.dll
Am I suppose to open the socket connection first and then call the AuthenticateAsClient() or just create the SslStream and call AuthenticateAsClient() ?
Is the SslStream the correct way to create secure socket connection? documentation shows how to use https but lacking examples of secure socket suppport.
Is TLS 1.3 default ? because the enum within the SslStream does not contain defintion for TLS 1.3 but the documentaiton TLS Client states TLS 1.3 is supported.
Default is 1.2
make sure the certificate is root certificate.
My server is a ASP.net web app with a self signed certificate.
Rtc has been set within a few minutes of current date
My server works with another console app as client.
It appears that on the server the AuthenticateAsServer() succeeds but the SCM20260E keeps throwing:
#### Message:
#### Network.SocketTls::OpenSocketTLS [IP: 0049] ####
#### Cleverhouse.Program::Main [IP: 001e] ####
Exception thrown: 'System.InvalidOperationException' in
System.InvalidOperationException: Exception was thrown: System.InvalidOperationException
Client code:
public void OpenSocketTLS(string serverAddress, int port)
InitClock();
IPAddress ip = IPAddress.Parse(serverAddress);
byte[] certificates = Certs.GetBytes(Certs.BinaryResources.forController);
X509Certificate[] certx509CA = new X509Certificate[] { new X509Certificate(certificates) };
_socket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
_socket.Connect(new IPEndPoint(ip, port));
SslStream socketStream = new SslStream(_socket);
socketStream.AuthenticateAsClient("DESKTOP-M8M6H10", certx509CA[0]);
Nvm manage to get it to work.
