Is there any secrett o get the sdcard working? I can write to the sdcard using the fez cobra 2 but sometime i have to take out the sdcard and format it on a comuter befre it will work.
Shouldn’t i be able to format from the board?
Using 32gb scdh cards…a cheapo and a samsung version.
I get the execpetion many times when i run
Any libraries or suggestions on how i can get a reliable sdcard logger working?
I use micro SD cards with all my boards and never had a single issue with them to date even with power on and off many times and I write to a log file every 60 seconds.
Is this with the Cobra board or a custom board?
Using the Fez Cobra 2…
The xecption i get is {System.InvalidOperationException}
mmm…should oSDCARD = new SDCard(); execute ven with out sdcard not installed?
Maybe is not a hardware thing?
There is an option to pass in the type, MCI or SPI. Try with this and see if it works.
SDCARD sdCard = new SDCard(GHI.IO.Storage.SDCard.SDInterface.MCI);
If there is no card you have to expect :
#### Exception System.Exception - 0xffffffff (1) ####
#### Message:
#### GHI.IO.Storage.SDCard::NativeConstructor [IP: 0000] ####
#### GHI.IO.Storage.SDCard::.ctor [IP: 0029] ####
#### GHI.IO.Storage.SDCard::.ctor [IP: 0005] ####
#### MFC.Program::Main [IP: 018a] ####
You should use a try and catch to detect a missing sd card.
Interesting, works fins in another project, so must have something to do with references or a conflict somewhere.
