Hi
I have finally made my code read from SDCard, so it’s is a succes.
I have seen this code used many places on the forum when working with SDCard
// evt is used to avoid the possibility that accesses to the
// mounted file system do not occur until mount()
// is fully done.
private static AutoResetEvent evt = new AutoResetEvent(false);
//Make sure to set the pin to your sd card detect pin.
private static InputPort sdCardDetect = new InputPort(GHI.Pins.FEZSpiderII.Socket5.Pin3, false, Port.ResistorMode.Disabled);
RemovableMedia.Insert += new InsertEventHandler(RemovableMedia_Insert);
RemovableMedia.Eject += new EjectEventHandler(RemovableMedia_Eject);
// Start auto mounting thread
new Thread(SDMountThread).Start();
evt.WaitOne(); // yield here until mounting and initializing is finished
// Your program goes here
// This event is fired by unmount; not neccesarily by physical ejection of media
static void RemovableMedia_Eject(object sender, MediaEventArgs e)
Debug.Print("SD card unmounted, eject event fired");
// as desired signal other thread(s) in application
// that unmount occurred
static void RemovableMedia_Insert(object sender, MediaEventArgs e)
Debug.Print("Insert event fired; SD card mount is finished.");
// insert code here for anything the program wants to do immediately
// after mounting occurs...
if (e.Volume.IsFormatted)
Debug.Print("Available folders:");
string[] strs = Directory.GetDirectories(e.Volume.RootDirectory);
for (int i = 0; i < strs.Length; i++)
Debug.Print(strs[i]);
Debug.Print("Available files:");
strs = Directory.GetFiles(e.Volume.RootDirectory);
Debug.Print("SD card is not formatted. Formatting...");
// VolumeInfo is the class that contains volume information for a specific
// media.
// .GetVolumes()[0] aquires the first volume on the device. Change the
// index for different volumes.
// .Format("FAT", 0); Selects the "FAT" file system as the format type.
VolumeInfo.GetVolumes()[0].Format("FAT", 0);
evt.Set(); // proceed with other processing
public static void SDMountThread()
SDCard SD = null;
const int POLL_TIME = 500; // check every 500 millisecond
bool sdExists;
try // If SD card was removed while mounting, it may throw exceptions
sdExists = sdCardDetect.Read();
// make sure it is fully inserted and stable
if (sdExists)
Thread.Sleep(50);
if (sdExists && SD == null)
SD = new SDCard();
SD.Mount();
else if (!sdExists && SD != null)
SD.Unmount();
SD.Dispose();
SD = null;
catch
if (SD != null)
SD.Dispose();
SD = null;
Thread.Sleep(POLL_TIME);
But when i used it on my Spider II board it didn’t work.
The sdCardDetect.Read() returned true when no card was inserted and false when card was inserted… So I reverted the sdExists check and now it works… So why does my Read check return the opposite than others using this code ??
The working SDMountThread code:
SDCard SD = null;
bool sdExists;
if (!sdExists)
Thread.Sleep(50);
if (!sdExists && SD == null)
SD = new SDCard();
SD.Mount();
else if (sdExists && SD != null)
SD.Unmount();
SD.Dispose();
SD = null;
catch
if (SD != null)
SD.Dispose();
SD = null;
