Here is a test app that I wrote to show some of the things I’m doing with this.
- countdown and time alarms
- persistent user storage
- persistent date time
So I only connect wifi to a NTP server if I press button 1, but the SD2405 has the date time kept current in it. SD2405 Real-Time clock Module(Arduino Gadgeteer Compatible)
using System.Collections;
using System.Net;
using System.Text;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using Gadgeteer.Modules.DFRobot;
using GHI.Processor;
using Microsoft.SPOT.Time;
namespace rtctest
public partial class Program
#region Confidential Settings
private const string SSID = "YourSSID";
private const string WIFI_PASSWORD = "YourPassword";
#endregion
//TimeServer Settings
private int _daylightSavingsShift;
private const int LocalTimeZone = -7 * 60;
private Font _font = Resources.GetFont(Resources.FontResources.NinaB);
timer.Tick +=<tab><tab>
timer.Start();
displayN18.Orientation = GTM.Module.DisplayModule.DisplayOrientation.UpsideDown;
var time = sD2405_Real_Time_Clock.GetDateTime();
Utility.SetLocalTime(time);
RealTimeClock.SetDateTime(time);
NetworkChange.NetworkAddressChanged += NetworkChange_NetworkAddressChanged;
NetworkChange.NetworkAvailabilityChanged += NetworkChange_NetworkAvailabilityChanged;
button.ButtonPressed += button_ButtonPressed;
button2.ButtonPressed += button2_ButtonPressed;
sD2405_Real_Time_Clock.CountDownAlarm += sD2405_Real_Time_Clock_CountDownAlarm;
sD2405_Real_Time_Clock.TimeAlarm += sD2405_Real_Time_Clock_TimeAlarm;
DisplayData(GetUserData()); //User Data could be something like the wifi password
private void DisplayData(string s)
displayN18.SimpleGraphics.ClearNoRedraw();
displayN18.SimpleGraphics.DisplayText(s, _font, GT.Color.Green, 0, 0);
displayN18.SimpleGraphics.DisplayText(DateTime.Now.Date.ToString(), _font, GT.Color.Red, 0, 15);
displayN18.SimpleGraphics.DisplayText(DateTime.Now.TimeOfDay.ToString(), _font, GT.Color.Red, 0, 35);
private string GetUserData()
var data = sD2405_Real_Time_Clock.GetUserData();
var charArray = Encoding.UTF8.GetChars(data);
return new string(charArray);
void sD2405_Real_Time_Clock_TimeAlarm(SD2405_Real_Time_Clock sender, SD2405_Real_Time_Clock.AlarmType type)
DisplayData("Time Alarm");
void sD2405_Real_Time_Clock_CountDownAlarm(SD2405_Real_Time_Clock sender, SD2405_Real_Time_Clock.AlarmType type)
DisplayData("Count Down");
void button2_ButtonPressed(GTM.GHIElectronics.Button sender, GTM.GHIElectronics.Button.ButtonState state)
var s = new string(charArray);
Debug.Print("User Data was " + s);
switch (sD2405_Real_Time_Clock.EnabledAlarm)
case SD2405_Real_Time_Clock.AlarmType.None:
sD2405_Real_Time_Clock.SetAlarmCountDown(1, SD2405_Real_Time_Clock.CountDownSpeed.Second, true);
//sD2405_Real_Time_Clock.DisplayRegisters("Count Down Alarm Set");
data = Encoding.UTF8.GetBytes("Count Down Alarm");
break;
case SD2405_Real_Time_Clock.AlarmType.CountDownAlarm:
sD2405_Real_Time_Clock.SetAlarmDateTime(0, 0, 0, 0, 0, 0,
(byte)(SD2405_Real_Time_Clock.Alarm.Second), true,
(byte)(SD2405_Real_Time_Clock.Days.Clear));
//sD2405_Real_Time_Clock.DisplayRegisters("Time Alarm Set");
data = Encoding.UTF8.GetBytes("Time Alarm");
break;
case SD2405_Real_Time_Clock.AlarmType.TimeAlarm:
sD2405_Real_Time_Clock.ResetAlarms();
//sD2405_Real_Time_Clock.DisplayRegisters("NO Alarm Set");
data = Encoding.UTF8.GetBytes("No Alarm Set");
DisplayData("No Alarms");
break;
sD2405_Real_Time_Clock.SetUserData(data);
void button_ButtonPressed(GTM.GHIElectronics.Button sender, GTM.GHIElectronics.Button.ButtonState state)
WifiSetup(SSID,WIFI_PASSWORD);
private void WifiSetup(string ssid, string key)
//wifiRS21.NetworkInterface.UpdateFirmware();
wifiRS21.NetworkInterface.Open();
wifiRS21.NetworkInterface.EnableDhcp();
wifiRS21.NetworkInterface.EnableDynamicDns();
try
wifiRS21.NetworkInterface.Join(ssid, key);
catch (Exception e)
Debug.Print(e.Message);
private void NetworkChange_NetworkAddressChanged(object sender, EventArgs e)
Debug.Print("Network Address Change to: " + wifiRS21.NetworkInterface.IPAddress);
if (wifiRS21.NetworkInterface.IPAddress != "0.0.0.0")
Debug.Print("Gateway Address: " + wifiRS21.NetworkInterface.GatewayAddress);
foreach (var dns in wifiRS21.NetworkInterface.DnsAddresses)
Debug.Print("DNS Address: " + dns);
// get Internet Time using SNTP
GetInternetTime();
Debug.Print(DateTime.Now.ToString());
wifiRS21.NetworkInterface.Disconnect();
wifiRS21.NetworkInterface.Close();
private void NetworkChange_NetworkAvailabilityChanged(object sender, NetworkAvailabilityEventArgs e)
//if (!e.IsAvailable)
// Debug.Print("Network disconnected");
Debug.Print("network is " + (e.IsAvailable ? "Available" : "Isn't Available"));
private void GetInternetTime()
try
var NTPTime = new TimeServiceSettings();
NTPTime.AutoDayLightSavings = true;
NTPTime.ForceSyncAtWakeUp = true;
NTPTime.RefreshTime = 3600;
//Thread.Sleep(1500);
NTPTime.PrimaryServer = Dns.GetHostEntry("2.ca.pool.ntp.org").AddressList[0].GetAddressBytes();
NTPTime.AlternateServer = Dns.GetHostEntry("time.nist.gov").AddressList[0].GetAddressBytes();
TimeService.Settings = NTPTime;
TimeService.SetTimeZoneOffset(LocalTimeZone); // MST Time zone : GMT-7
TimeService.SystemTimeChanged += OnSystemTimeChanged;
TimeService.TimeSyncFailed += OnTimeSyncFailed;
TimeService.Start();
//Thread.Sleep(500);
TimeService.UpdateNow(0);
//Thread.Sleep(9000);
//Debug.Print("It is : " + DateTime.Now);
var time = DateTime.Now;
sD2405_Real_Time_Clock.SetDateTime(time);
TimeSpan diff = DateTime.Now.Subtract(sD2405_Real_Time_Clock.GetDateTime());
DisplayData(FormatDuration(diff));
TimeService.Stop();
catch (Exception ex)
Debug.Print(ex.Message);
private string FormatDuration(TimeSpan x)
return x.Days.ToString("D") + ":" + x.Hours.ToString("D2") + ":" + x.Minutes.ToString("D2") + ":" +
x.Seconds.ToString("D2") + "." + x.Milliseconds.ToString("D3");
private void OnSystemTimeChanged(object sender, SystemTimeChangedEventArgs e)
// Called on successful NTP Synchronization
var now = DateTime.Now; // Used to manipulate dates and time
#region Check if we are in summer time and thus daylight savings apply
// Check if we are in Daylight savings. The following algorithm works pour Europe and associated countries
// In Europe, daylight savings (+60 min) starts the last Sunday of march and ends the last sunday of october
var aprilFirst = new DateTime(now.Year, 4, 1);
var novemberFirst = new DateTime(now.Year, 11, 1);
var sundayshift = new[] { 0, -1, -2, -3, -4, -5, -6 };
var marchLastSunday = aprilFirst.DayOfYear + sundayshift[(int)aprilFirst.DayOfWeek];
var octoberLastSunday = novemberFirst.DayOfYear + sundayshift[(int)novemberFirst.DayOfWeek];
if ((now.DayOfYear >= marchLastSunday) && (now.DayOfYear < octoberLastSunday))
_daylightSavingsShift = 60;
_daylightSavingsShift = 0;
TimeService.SetTimeZoneOffset(LocalTimeZone + _daylightSavingsShift);
#endregion
// Display the synchronized date on the Debug Console
now = DateTime.Now;
var date = now.ToString("dd/MM/yyyy");
var here = now.ToString("HH:mm:ss");
Debug.Print(date + " // " + here);
private void OnTimeSyncFailed(object sender, TimeSyncFailedEventArgs e)
// Called on unsuccessful NTP Synchronization
Debug.Print("NTPService : Error synchronizing system time with NTP server");
private void _realTimeClock_TimeAlarm(SD2405_Real_Time_Clock sender, SD2405_Real_Time_Clock.AlarmType type)
Debug.Print("Time Alarm!!");
var test = sD2405_Real_Time_Clock.GetDateTime();
Debug.Print(test.ToString());
private void _realTimeClock_CountDownAlarm(SD2405_Real_Time_Clock sender, SD2405_Real_Time_Clock.AlarmType type)
Debug.Print("Count Down Alarm!!");
