I’m currently working on a SD card library for NETMF. The speed I’m currently reaching is so fast that I’d like to share this info to the community. (I actually had to slow the clock down to make sure SDRAM could follow :p)
Current speed on FAT32 formatted SD-card is around 3.44MByte / s (see screenshot).
I still have some work on the library as it now seems that I need to reset the board if I want to start a new debug session…
Architect: I will not open-source the library. In fact it is an RLP port of the open-source FatFs (FAT file system module) by Chan, who did some amazing work: FatFs - Generic FAT Filesystem Module
@ mytech: I might sell the library, but I’m currently struggling with the debugger.
When visual studio resets the board before deploying, I hear the USB unplug sound, but the board doesn’t come back. I need to hit the reset button manually before deploy continues…
Seems like it has something to do with the RLP InstallInterrupt function, but can’t figure it out. Maybe it’s a bug in the RLP framework?
The issue with VS is a common one, this happens to me a lot especially if i have multiple VS windows open… so it is a bug somewhere but can’t pinpoint it either… and i do not use RLP…
