Thanks for the quick follow-up – the Netduino folks may have submitted a patch, as they’ve fixed this in their implementation. Not sure if it’s in a NETMF tracking system or anything.
I was able to implement a workaround – basically I just wrap the underlying SD stream in a stream that will only do 256-byte reads. This fixes my problem, but it may not be terribly general purpose. I’m including it here.
Thanks for the help!
// There are some stream implementations that behave poorly when given
// random read sizes. In order to mitigate this, FixedBufferReadStream
// will wrap an underlying stream, and only do reads of a fixed size.
// Note that this will "over-read" from the underlying stream by as
// much as the buffer size.
// This class does not take ownership of the underlying stream. Most
// notably, Dispose will not do anything to it.
class FixedBufferReadStream : Stream
private Stream stream;
private byte[] buffer;
private int lastBytesRead;
private int offset;
public FixedBufferReadStream(Stream stream, int bufferSize)
this.stream = stream;
this.buffer = new byte[bufferSize];
RefillBuffer();
private void RefillBuffer()
this.lastBytesRead = stream.Read(buffer, 0, buffer.Length);
this.offset = 0;
public override int Read(byte[] buffer, int offset, int count)
int bytesToCopy = (count < (lastBytesRead - this.offset)) ? count : (lastBytesRead - this.offset);
for (int counter = 0; counter < bytesToCopy; ++counter)
buffer[offset + counter] = this.buffer[this.offset + counter];
this.offset += bytesToCopy;
if (this.offset == this.lastBytesRead)
RefillBuffer();
return bytesToCopy;
#region Unimplemented Stream members
public override bool CanRead
get { throw new System.NotImplementedException(); }
public override bool CanSeek
public override bool CanTimeout
get
return base.CanTimeout;
public override bool CanWrite
public override void Flush()
public override long Length
public override long Position
get
set
public override void Write(byte[] buffer, int offset, int count)
public override void SetLength(long value)
public override long Seek(long offset, SeekOrigin origin)
#endregion
We have a firmware in the beta page but there is no access for “Newbie”. Please send us an email with link to this post so we can email you the firmware.
