SD card object initialization problem
Hello,
I have EMX module with SD card connector. When I’m starting my program, it causes exceprion at
GHI.Premium.IO.PersistentStorage
when initializing
_sd
object. Here is my code:
if (PersistentStorage.DetectSDCard())
                 _sd = new PersistentStorage("SD");//Here is the exception
                Thread.Sleep(3000);
                _sd.MountFileSystem();
Debug output:
>> Mounting SD...
    #### Exception System.Exception - 0xffffffff (1) ####
    #### Message:
    #### GHI.Premium.IO.PersistentStorage::.ctor [IP: 0000] ####
    #### FTPServer.Program::Main [IP: 002d] ####
My SDK Version is 1.0.2, .NET MF is 4.2.9
Any ideas?
@ andre.m - Here is it:
      static  PersistentStorage _sd;
       static SPI MySPI;
        static NetworkManager nm;
        static NameService ns;
        static FTPServer ftp;
        private static EthernetBuiltIn eth0 = new EthernetBuiltIn();
            Debug.Print("");
            Debug.Print("Micro FTP Server FTPcko");
            Debug.Print("---------------------");
            // Mount SD card
            Debug.Print(">> Mounting SD...");
                Thread.Sleep(3000);
What kind of File System has your SD-Card?
EMX only support:
Note: Only FAT32/FAT(FAT16)
Link:
http://www.ghielectronics.com/downloads/NETMF/Library%20Documentation%20v4.2/Premium/Index.html
@ Uuuups - I’m using FAT 32
@ andre.m -
At this line:
I have EMX on custom board, it’s Freescale Tower System adapted board. Which pins you want to know?
@ andre.m - Yes, you were right, one of the SD pins was broken. Thank you.
